Gene J Posted January 4, 2008 Share Posted January 4, 2008 I remember reading somewhere we should not use petroleum based lube for the brake sliders because it will cause the rubber parts to swell. What else is there??? Quote Link to comment Share on other sites More sharing options...
pennswoodsed Posted January 4, 2008 Share Posted January 4, 2008 silicone avail in 1/2oz/ 14 gm tubes for $3.00 or 200gm bottles for $8.00 whoch is more than you and your extended family use,ever ps make any ridges or grooves in sliders smooth with file,grinder or my personality for best action and longest pad life Quote Link to comment Share on other sites More sharing options...
Strakes Posted January 4, 2008 Share Posted January 4, 2008 I don't know about the swelling that you're talking about. I recommend any brake specific grease/lubricant. Make sure it's brake specific. They are readily available at the local parts store. I have used and have been satisfied with both AGS Sil-Glyde brake lubricant and CRC's Sta-lube brake lubricant. Quote Link to comment Share on other sites More sharing options...
OB99W Posted January 5, 2008 Share Posted January 5, 2008 [...]ps make any ridges or grooves in sliders smooth with file,grinder or my personality for best action and longest pad lifeAre you really that abrasive? I don't know about the swelling that you're talking about.[...]Petroleum will cause many rubber compounds to swell and/or soften. Therefore, lubricants designed for brake calipers don't tend to have a petroleum base, although there may be a limited amount of petroleum content to help keep the rubber parts from hardening. Sil-Glide is silicone-based, and as far as I know, the Sta-Lube product for brakes is mostly synthetic. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted January 5, 2008 Share Posted January 5, 2008 Right on, so don't use vaseline for brakes! Some lubes... Quote Link to comment Share on other sites More sharing options...
idosubaru Posted January 5, 2008 Share Posted January 5, 2008 yep, any auto parts store will have this stuff, just make sure it's brake specific lube, that's all. they typically sell little tiny packets of it at the counter as well per job. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted January 7, 2008 Share Posted January 7, 2008 The special Subaru red 'niglube' comes with the caliper reseal kits. Quote Link to comment Share on other sites More sharing options...
