foamy oil in the air filter, Yikes
I doubt he has blow-by. That's extreemely uncommon for these engines. It's probably bad PCV valve and PCV filter, along with accumultion of carbon and other deposits in the breather lines.
It's best to replace the larger lines with 5/8" heater core hose, and blow out/replace all the smaller lines. Replace the pcv filter in the airbox and the pcv valve with OEM parts ONLY.
