xbalancex7 Posted January 10, 2008 Share Posted January 10, 2008 Hey guys, will you give me estimates on what your rpms tack at say 65mph, and what tranny/ size tires you have. currently I have an auto with 3.70 and it tacks about 3600 rpms at 65. What does your 5speed d/r tack at 65mph? Link to comment Share on other sites More sharing options...
hyrysc Posted January 10, 2008 Share Posted January 10, 2008 Hey guys, will you give me estimates on what your rpms tack at say 65mph, and what tranny/ size tires you have. currently I have an auto with 3.70 and it tacks about 3600 rpms at 65. What does your 5speed d/r tack at 65mph? I have slightly larger tires, so my MPH is reading about 60 when my GPS says I am going 65, but my RPM's are about 2700 - 2800. I have a 5 speed. Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted January 10, 2008 Share Posted January 10, 2008 Lucky. I'm at 4000-4200 at 70, with stock 175's on. I do have a 4speed though. Link to comment Share on other sites More sharing options...
audio_file Posted January 10, 2008 Share Posted January 10, 2008 it took me awhile to get used to this 3AT . . . with my 15" pugs and 60 series tires my tach is just under 4K at 65mph, the freeway speed limit in my area is 70. I'm sure the speedo is off because of the diameter change on the wheels/tires, maybe by 7mph or so, which puts me right at/above the limit at 4k. I thought that was pretty extreme until I drove my gf's Scion Tc (2006) with a 5sp manual, and it is at 3700 rpm at 70! :eek: I drove (in my car sales days) a 2007 corvette cpe with a 6spd manual, and in 6th gear it almost idled down the freeway in 6th gear, something like 1800 rpm and would still accelerate like a mofo! Link to comment Share on other sites More sharing options...
idosubaru Posted January 10, 2008 Share Posted January 10, 2008 Johnson']Lucky. I'm at 4000-4200 at 70' date=' with stock 175's on. I do have a 4speed though.[/quote'] sounds about what i'm used to in the 5 speeds of the XT's. they run close to 4,000 at 70/75mph i believe, one reason i don't like them as a travel car as they are very loud. Link to comment Share on other sites More sharing options...
bratsrus1 Posted January 11, 2008 Share Posted January 11, 2008 Ney X7 This is Jerry, i have a 86 EA81 hatch that has a RX 5 speed dual range tranny with 3.70 gears. At 65 mph the tach is at 3000 rpm, you have the same gears that i have. I think your auto tranny mush be slipping, it could be that the auto tranny has lower gears in it. I also have the stock tire size 185R 70X13. Thanks Jerry Link to comment Share on other sites More sharing options...
ScottG Posted January 11, 2008 Share Posted January 11, 2008 I've got 175R65X13 tires on an 86 GL10 wagon 2WD. My tach reads 3K at 65. I can get 35MPG if I keep it just under 3K....about 61/62 MPH. Link to comment Share on other sites More sharing options...
lostinthe202 Posted January 11, 2008 Share Posted January 11, 2008 stock (as far as I know) ea81 hatch 4speed, about 3k at 65mph Edit - tires are 185/70 r13 Link to comment Share on other sites More sharing options...
cobcob Posted January 11, 2008 Share Posted January 11, 2008 stock (as far as I know) ea81 hatch 4speed, about 3k at 65mph Bout the same here stock EA81 Brat with S/R 4spd, I was seeing about 3200 @ 65mph... Then the stupid Equus aftermarket digital tach took a dump Link to comment Share on other sites More sharing options...
ivantruckman Posted January 11, 2008 Share Posted January 11, 2008 3at 175 70, runs 4000 at 55 mph... weeeeeeee. / my 86 dr 5 speed, with 205 65 15 spins about 2300 at 55 Link to comment Share on other sites More sharing options...
subiemech85 Posted January 12, 2008 Share Posted January 12, 2008 and in the ski wagon with 3.9 rear end and top gear ratio of .971 3k = 55 4k = 70 3.5k = 65? Link to comment Share on other sites More sharing options...
subaruguru Posted January 12, 2008 Share Posted January 12, 2008 5speed d/r 3.90 205r15s befor the weber i think was 3000 at 60 65 my 1980 gl-5 1600 4.11 2wd 5 speed 4000 at 85 90 Link to comment Share on other sites More sharing options...
