Block sealant
Flow
I don't know what you mean by sealing up the motor...but if you mean to be putting the two block halves together....RTV is not recommended...it does not mix with oil,...is dangerous if a small piece gets into the bearing etc....I know in my gasket kits that the black RTV is always supplied, but I never use it...call up the Permatix people and have them recommend something other and better for your application
