Will an EJ20 or EJ22 fit in to one of these?
kiwi subbie
SOHC EJ will fit with like 1/2" of clearance on either side by the frame rails. Tailgatewagon mocked one up into a gen 1 stage 2 car and came up with the final measurment. Yes, lots of tranny tunnel beating is required to get it to fit right and the engine crossmember will need the engine mount holes ovaled out to fit the EJ mounts in there.
  Phizinza said:
6" lift, EJ22, 5sp D/R... She'll be good.. :burnout:
Or just onroad stuff?
The EA81 is the same width as the EA71 I believe, so it should fit a SOHC EJ. You'll need to crack out the tape measure.
ea81 is slighty more wider than an EA71. did get that measured.
i am trying 2 track down an GFT or GL 1600 at the moment.
