86subaru Posted January 12, 2008 Share Posted January 12, 2008 it works great, here are my codes, p0106 barmetic pressure range, p0115 coolant temp, p0303 misfire #3 , p0035 knock sensor , p0105 manafold, but no check engine light on, should i clean all the codes and then check again, ? which is # 3 ? but iam going to change all the plugs + wires , this is on a 95 legacy L 2.2 motor a/t awd wagon , thanks Link to comment Share on other sites More sharing options...
Skip Posted January 12, 2008 Share Posted January 12, 2008 howdy Jim, nice seeing you around. With all those codes stored you should have seen the CEL on, if they were not ghost codes. Couple thoughts 1)Does the check engine light illuminate when the key is turned to "on" but the engine is not started? yes( ) no ( ) 2) Has the car ever failed to start since you've owned it? yes ( ) no ( ) Clear the codes and drive it for several cycles - report the new codes. I know you use NGK plugs Please only use OEM wires Link to comment Share on other sites More sharing options...
86subaru Posted January 12, 2008 Author Share Posted January 12, 2008 yes and no, the car has 164,000mi on it also, that is what i was thinking [ ghost codes], i have never changed the plugs/wires , things i changed ,fuel filter, pvc, cleaned maf , air filter, but mpg is way down like 14 , yes i have a set of oem plugs / wires ,+ a good coolant temp sensor, . thanks will do ,one other thing, the idle goes up and down ,even after the car is warmed up ? Link to comment Share on other sites More sharing options...
Skip Posted January 12, 2008 Share Posted January 12, 2008 "the idle goes up and down ,even after the car is warmed up ?" This could be related to the CTS problem or an IAC problem - I know you know about them on EA82 SPFI cars. EJ's have them also, beside the throttle body pass side. Link to comment Share on other sites More sharing options...
86subaru Posted January 12, 2008 Author Share Posted January 12, 2008 checked it again, knock sensor, barometic pressure range, some times when you start the car the first time it will not start right away , if you turn the key back and try again it will start, Link to comment Share on other sites More sharing options...
Skip Posted January 12, 2008 Share Posted January 12, 2008 doubt those would cause hard starting but knock sensor is probably the old style prone to cracking and going bad -- several recent posts on where it is, how much and how to replace Baro sensor is located on the pass side inner fender right beside the pressure exchange solenoid. Has vacuum lines and an electric line running to it. Try 1stsubaru.com for a replacement if the code keep coming back. (my 97 OB has this problem as I type) Did you do the plugs and wires yet? They may help with the starting issue esp if it's cold and damp. Link to comment Share on other sites More sharing options...
86subaru Posted January 12, 2008 Author Share Posted January 12, 2008 ok on the knock sensor, will change the plugs/ wires, thanks Link to comment Share on other sites More sharing options...
MilesFox Posted January 12, 2008 Share Posted January 12, 2008 the no starting issue is probaby the cam angle sensor. my car does it, and will start if i wiggle it. i have read other posts abouthtis problem. the dealer tells me it was common problem, a newone is about 45 bucks. speaking of ghost codes, and pertaining to a 2000 mitsu mirage, it had the check engine light and i replaced the plugs and wires. the light is not on anymore, but it pulls a code for #3 misfire. so, can the codes be cleared with out an obd scanner? Link to comment Share on other sites More sharing options...
86subaru Posted January 12, 2008 Author Share Posted January 12, 2008 not sure if you can or not, but i cleared mine with my ob2 scanner, i replaced the crank sensor already, so it starts after you shut it off for 5 mins or so and restart fine now, Link to comment Share on other sites More sharing options...
OB99W Posted January 13, 2008 Share Posted January 13, 2008 [...]mpg is way down like 14[...]the idle goes up and down ,even after the car is warmed up ?Poor gas mileage and erratic idle speed (loping idle, if that's what it's doing) point to an overly rich mixture. As Skip mentioned, a CTS problem could cause this; if the ECU thinks the engine hasn't warmed, it will run "open loop" (default rich mixture) all the time. The CTS isn't the only possible cause, but I'd consider it first, given the symptoms. Link to comment Share on other sites More sharing options...
86subaru Posted January 13, 2008 Author Share Posted January 13, 2008 ok thanks, the scanner will give how the engine is running while running also, mixture, etc... Link to comment Share on other sites More sharing options...
idosubaru Posted January 13, 2008 Share Posted January 13, 2008 i've seen bad sensors not throw the check engine light on XT6's. once was the coolant temperature sensor and once was the O2 sensor. both caused drivability issues, the CEL never came on and it worked. not sure why that can happen, but it does. both times the problem was directly fixed by replacing those parts. pay attention to the CTS - the sensors themselves on the older subaru's never actually fail. the connectors get corroded and dirty preventing a good connection. cleaning is the key. a new sensor often alleviates the problem temporarily because the contacts are clean...but the harness/connector is still dirty so it may come back rather quickly. Link to comment Share on other sites More sharing options...
