benc. Posted January 14, 2008 Share Posted January 14, 2008 i am installing a new water pump on my 98 2.5, my question is, I am reusing the plastic curve pipe thingy under the water pump, and when I tighten it on my new water pump, there is a gap (around 1/8") in the center of it, away from the two bolts. where as the contact area directly under the 2 bolts has a good seal. it seems the plastic pipe thingy is warped in the center, is this normal? I have checked the rubber seal for the thermostat and its not being caught in the center. Thanks! Quote Link to comment Share on other sites More sharing options...
lmdew Posted January 14, 2008 Share Posted January 14, 2008 1/8" would be a little much, but they do bend slightly. You may have over tightened the bolts. You can pick up the metal one off a early 90's 2.2 and replace the plastic. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted January 15, 2008 Share Posted January 15, 2008 It might be warped. Woah those are available in metal? Darn I just bought the replacement plastic ones. I think that part is 11060AA070 HOUSING FOR THERMOSTAT FOR 1995-2006 LEGACY OUTBACK & SUS (NON-H6 NON-TURBOS) ALL. Quote Link to comment Share on other sites More sharing options...
