brokebill Posted January 15, 2008 Share Posted January 15, 2008 when setting the timing on my carbed 86 GL, after unhooking the hoses for my vacuum advance do i plug them or just let em suck? Link to comment Share on other sites More sharing options...
ivantruckman Posted January 15, 2008 Share Posted January 15, 2008 i would plug them. the car may not idle properly Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 16, 2008 Share Posted January 16, 2008 If it's carbed then there's no vacuum signal to the distributor at idle with the throttle closed. So it really doesn't matter, and shouldn't actually affect your timing settings either way. Disconnecting them really isn't even required because of this. GD Link to comment Share on other sites More sharing options...
Gloyale Posted January 16, 2008 Share Posted January 16, 2008 GeneralDisorder said: If it's carbed then there's no vacuum signal to the distributor at idle with the throttle closed. So it really doesn't matter, and shouldn't actually affect your timing settings either way. Disconnecting them really isn't even required because of this. GD It matters about 2 degrees. Which does equal almost nothing Link to comment Share on other sites More sharing options...
brokebill Posted January 16, 2008 Author Share Posted January 16, 2008 Gloyale said: It matters about 2 degrees. Which does equal almost nothing so should i plug em for accuracy? Link to comment Share on other sites More sharing options...
Gloyale Posted January 16, 2008 Share Posted January 16, 2008 The proceedure recommended for the timing is to disconnect and plug the vaccuum line to the disty. Link to comment Share on other sites More sharing options...
