isleymerl Posted January 15, 2008 Share Posted January 15, 2008 I am not finding it in my book. Maybe I have chiltons syndrome? I just can't seem to find it. Link to comment Share on other sites More sharing options...
Skip Posted January 15, 2008 Share Posted January 15, 2008 here is a great post on it http://www.ultimatesubaru.org/forum/showthread.php?t=82144&highlight=purge Little long but has all you need to know. Newer engine but yours is the same. I'm still looking for a picture of the purge valve postion. It's under the under the 1/3 intake runner. Hope this helps a little Link to comment Share on other sites More sharing options...
OB99W Posted January 15, 2008 Share Posted January 15, 2008 I am not finding it in my book. Maybe I have chiltons syndrome? I just can't seem to find it.As Skip said, it's under the #3 intake runner. Does this help, or make things worse? : Link to comment Share on other sites More sharing options...
isleymerl Posted January 16, 2008 Author Share Posted January 16, 2008 haveing problems with code 35 and determing if it as any thing to do with my idle problem, dies when first started unless i gas it . Link to comment Share on other sites More sharing options...
Skip Posted January 16, 2008 Share Posted January 16, 2008 Mr. Isley sir, that problem sounds more like a coolant sensor or IAC valve problem. By chance do the radiator cooling fans run when the key is turned "on" and the AC and defrost are "off"? This is an indication the Fuel injection coolant thermosensor is faulty. Link to comment Share on other sites More sharing options...
