msmithmmx Posted January 19, 2008 Share Posted January 19, 2008 The specifics, 97 OBW 2.2 with 180K. Here is my problem and it happens when it is REALLY cold outside (32 and below). The brake pedal at startup is very stiff, and will not stop the car. That goes on for 3-4 seconds then goes away never to return. If I let the car warm up for a few minutes then drive I have no issues. What I did::: The fluid was bad off, looked like used motor oil. I flushed the system, I used the motive pump I just purchased what a great job. That helped somewhat, now it has to be 20 degrees for it to happen. Am I loosing boost? Could I have a leak in the booster? Seems like its not charging at startup?. Generally the pedal is somewhat stiff but at start up it does not budge. I did a engine swap recently and I do not know if I had the problem before as I never drove the car with the 2.5 in it. I have another sub I did the sam swap on with no issues. Any thoughts. There is a 99 Forester at the local bone yard so parts will be cheap if I need them. Link to comment Share on other sites More sharing options...
Gene J Posted January 19, 2008 Share Posted January 19, 2008 I am almost positive there was a recall of the master cylinder for this very symptom. At least there was on my 98 GT. Campaign Number: 99V040000 Date: 1999-Mar-03 Component: Service Brakes, Hydraulic: Foundation Components: Master Cylinder Defect Summary: VEHICLE DESCRIPTION: PASSENGER AND SPORT UTILITY VEHICLES EQUIPPED WITH ANTI-LOCK BRAKING SYSTEM (ABS). (THE 1999 2.2 LITER LEGACY VEHICLES ARE EXCLUDED). IN EXTREMELY COLD WEATHER, THE BRAKE PEDAL GOES TO THE FLOOR AND THE VEHICLE STOPPING DISTANCE IS INCREASED. Consequence Summary: THIS CONDITION CAUSES THE VEHICLE STOPPING DISTANCE TO BE INCREASED, POSSIBLY RESULTING IN A CRASH. Corrective Summary: DEALERS WILL REPLACE THE BRAKE MASTER CYLINDER. Sorry. Close but no cigar... Link to comment Share on other sites More sharing options...
msmithmmx Posted January 19, 2008 Author Share Posted January 19, 2008 I called the dealer, my car is not effected. There was only one open recall and that was for a front spring adjustment. Link to comment Share on other sites More sharing options...
Skip Posted January 19, 2008 Share Posted January 19, 2008 This problem has been covered recently and is normaly attributed to moisture in the vacuum booster line. IIRC, there is a check valve that freezes, preventing vacuum from reaching the booster. You can remove the line and spray a moisture displaceant into it. I'll see if I can find the post on it. Link to comment Share on other sites More sharing options...
Gloyale Posted January 19, 2008 Share Posted January 19, 2008 The check valve in the vaccuum line to the brake booster gets frozen shut. Remove the valve, spray wd-40 inside to evaporate the moisture. That ussually helps. Don't let anyone tell you you need a master cylinder, not even the dealer. It is the Check valve. a $5 dollar part, and all it needs is a bit of WD-40. I lived in wisconsin for 5 year so I had this problem first hand Link to comment Share on other sites More sharing options...
Skip Posted January 19, 2008 Share Posted January 19, 2008 try this post/thread Hope it helps http://www.ultimatesubaru.org/forum/showthread.php?t=83038&highlight=booster+freeze Link to comment Share on other sites More sharing options...
msmithmmx Posted January 19, 2008 Author Share Posted January 19, 2008 Thats my problem to a T. Lovely, easy fix. Link to comment Share on other sites More sharing options...
Skip Posted January 19, 2008 Share Posted January 19, 2008 You're welcome Hope it's an easy/cheap fix. Link to comment Share on other sites More sharing options...
gohawks Posted January 19, 2008 Share Posted January 19, 2008 Woke up this morning and had the same problem. I took off the hose and sprayed some wd40 in there. Blew some compressed air in the hose and replaced. We'll see what happens tomorrow morning. Thanks all. Link to comment Share on other sites More sharing options...
msmithmmx Posted January 20, 2008 Author Share Posted January 20, 2008 OMG, I sprayed some WD40 in the pipe until it ran through and then blew some air in it. WOW, my brakes are 100% better. Link to comment Share on other sites More sharing options...
ericem Posted January 21, 2008 Share Posted January 21, 2008 Yup WD40 worked for me as well! Link to comment Share on other sites More sharing options...
gohawks Posted January 21, 2008 Share Posted January 21, 2008 so far so good for me as well. gotta love a cheap fix. Link to comment Share on other sites More sharing options...
nipper Posted January 21, 2008 Share Posted January 21, 2008 How to tell its cold out, Blu has no brakes as i back out of the driveway (well i stand on the pedal and its fine). Next thaw I have to spray too. nipper Link to comment Share on other sites More sharing options...
BudB Posted January 27, 2014 Share Posted January 27, 2014 Our 2005 Forester has a similar problem--when it is less than 20 deg F, you have to use an ungodly amount of force on the brake pedal to activate the brakes until it warms up or the brakes have been used a few times, then they are normal. I have had the local Subaru dealer look at it several times and even suggested to them that it was a check valve. They replaced other brake parts and the problem continues. Does this model have a check valve that can be WD40'd or replaced? Seems like something I should be able to do myself but I could also use a diagram showing where this is (assuming we have one!) Many thanks! Bud Link to comment Share on other sites More sharing options...
porcupine73 Posted January 27, 2014 Share Posted January 27, 2014 I've had this problem on my '94 Legacy many times. It's been especially bad this year, but then, it's been especially cold around here the last couple months. On mine, the first couple of brake presses work fine. But that third or fourth press - that's when it acts up. And that is the worst time for it to do so. I have trained myself to press the brake about a dozen times before shifting out of park. When I get to that 3rd or so press I feel the pedal get hard, then I keep nancying the pedal along until I feel it release. Then it's fine after that, until it cools overnight and repeats the issue the next day. I sprayed some lube in there a couple years ago, I think it's time for a refresh. Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 27, 2014 Share Posted January 27, 2014 On 1/27/2014 at 3:53 PM, BudB said: Our 2005 Forester has a similar problem--when it is less than 20 deg F, you have to use an ungodly amount of force on the brake pedal to activate the brakes until it warms up or the brakes have been used a few times, then they are normal. I have had the local Subaru dealer look at it several times and even suggested to them that it was a check valve. They replaced other brake parts and the problem continues. Does this model have a check valve that can be WD40'd or replaced? Seems like something I should be able to do myself but I could also use a diagram showing where this is (assuming we have one!) Many thanks! Bud Yes, every car has one. It is in the middle of the brake booster vacuum hose which leads from the engine to the brake booster servo. Open the hood and look at the large round (probably painted black) cylinder behind the brake fluid reservoir. It will have a metal nipple sticking out towards the engine with a large hose attached. (Approx. 5/8" diameter) Loosen the clamps with a pair of pliers, remove the hose from the booster and engine. Be sure to note which end goes where, since it will not hold vacuum in the booster if you reinstall the hose backwards. Spray wd40 linerally into either end, until it runs out the other side. Blow it out with compressed air if available. Link to comment Share on other sites More sharing options...
BudB Posted January 27, 2014 Share Posted January 27, 2014 Thanks for your excellent answer! I'm hoping that will resolve this issue for us! Bud Link to comment Share on other sites More sharing options...
BudB Posted January 27, 2014 Share Posted January 27, 2014 On 1/27/2014 at 5:48 PM, Fairtax4me said: Yes, every car has one. It is in the middle of the brake booster vacuum hose which leads from the engine to the brake booster servo. Open the hood and look at the large round (probably painted black) cylinder behind the brake fluid reservoir. It will have a metal nipple sticking out towards the engine with a large hose attached. (Approx. 5/8" diameter) Loosen the clamps with a pair of pliers, remove the hose from the booster and engine. Be sure to note which end goes where, since it will not hold vacuum in the booster if you reinstall the hose backwards. Spray wd40 linerally into either end, until it runs out the other side. Blow it out with compressed air if available. Thanks for your excellent answer. I'm crossing my fingers that this will fix this stubborn problem for us! Bud Link to comment Share on other sites More sharing options...
BudB Posted January 27, 2014 Share Posted January 27, 2014 On 1/27/2014 at 4:53 PM, porcupine73 said: I've had this problem on my '94 Legacy many times. It's been especially bad this year, but then, it's been especially cold around here the last couple months. On mine, the first couple of brake presses work fine. But that third or fourth press - that's when it acts up. And that is the worst time for it to do so. I have trained myself to press the brake about a dozen times before shifting out of park. When I get to that 3rd or so press I feel the pedal get hard, then I keep nancying the pedal along until I feel it release. Then it's fine after that, until it cools overnight and repeats the issue the next day. I sprayed some lube in there a couple years ago, I think it's time for a refresh. Sounds just like our Forester. I'm going to pass along your advice to my son who has the car at college. It matches what I have suggested to him. Thanks so much! Link to comment Share on other sites More sharing options...
