mudrat79 Posted December 17, 2003 Share Posted December 17, 2003 Ok Here goes... Car is an 88 AWD XT-6 ....... Car has issue's with Air Ride system and Diff Lock......???? First issue....... Does Air Pump in Fender have it's Own fuse...? If so, Where is it Located....? Second Issue......A Subaru Shop Here in town while in the Process of trying to figure out Air Ride Somehow Got Diff-Lock Engaged, and Now it won't come out...... 1.....???? Where is the switch for Diff-Lock Located, ( most are in the center console right...? ) thise car has an un-labeled switch located just forward of E-Brake handle...? 2.......???? Does it have a fuse....? lastly......... If I have to Pull Air Ride Struts, and Stuff Standards in, Will Wagon or 3 Door Struts Fit the bill....?????? All info is Greatly apreciated..... Thanks in advance, John in Eugene........ Link to comment Share on other sites More sharing options...
Hondasucks Posted December 17, 2003 Share Posted December 17, 2003 AS far as I know the rears are the same, I have 4WD XT6 rear control arms in my turbowagon, with the wagon struts. As for the front, they are different. You could either use 2WD XT6 struts, which will bolt right in, or you can use Legacy struts, which work but I think you need to grind out the tower a little bit where teh strut bolts in at the top. As for the air ride, I have no idea Diff lock - that unlabled switch might be it, if I remember correctly the diff lock in an XT is on the center console and its a flat switch, it's not a turn switch like in the RX. Link to comment Share on other sites More sharing options...
WagonsOnly Posted December 17, 2003 Share Posted December 17, 2003 I think...not certain though...that the switch just in front of the E-brake is for the fog lights? I'll check my OM tomorrow. Link to comment Share on other sites More sharing options...
XSNRG Posted December 17, 2003 Share Posted December 17, 2003 Two things that will lock up the diff lock (rectangular switch on console) Tires of different sizes or inflation or a vacuum leak at or near the vacuum selenoid. You could possibly manually shift the lever from under the car. I'm not sure about actual fitment of the GL struts but I do know they are much longer and prferably, you are looking for 2wd XT-6 struts, they are non-air and they are short. I can't help with the other questions. Link to comment Share on other sites More sharing options...
Hondasucks Posted December 17, 2003 Share Posted December 17, 2003 The XT6 struts attact to the knuckle in a COMPLETELY different way than other EA series struts, they are NOT interchangable! Link to comment Share on other sites More sharing options...
Dennis ex24 Posted December 17, 2003 Share Posted December 17, 2003 air ride has a fuse in the fuse box with all the other fuses...that circuit also controls the power door locks. Link to comment Share on other sites More sharing options...
northguy Posted December 17, 2003 Share Posted December 17, 2003 If you're thinking about 86ing the air ride and going to regular struts, I recall back in July I searched the archives and found a aprticularly good set of articles that dealt with the different struts and mods needed - name brands and costs - to make the swap. It would be worth the time to do the search. Link to comment Share on other sites More sharing options...
ShawnW Posted December 17, 2003 Share Posted December 17, 2003 the large switch in the e brake console is the diff lock switch. Link to comment Share on other sites More sharing options...
XSNRG Posted December 17, 2003 Share Posted December 17, 2003 BTW, The guy at the Rally X with the XT-6 said he swapped on Legacy or Impreza struts, but those made it sit pretty high and he wasn't very happy with them. 2WD XT-6 is the most straightforward solution. Link to comment Share on other sites More sharing options...
mudrat79 Posted December 17, 2003 Author Share Posted December 17, 2003 Hey all, Thanks for the responses..... I'll be working on it today, See what happens.....????? Till then, John......... Link to comment Share on other sites More sharing options...
c150L Posted December 18, 2003 Share Posted December 18, 2003 There is also a thermal overload breaker built into the compressor motor. I ran into 2 of them that appearently the compressor had run too much and burned out (expired) this internal safety. One comperssor, I opened up and bypassed that thing, cleaned brushes and comm. I know, probably not the best thing to do, but I got another year out of that compressor untill I loaned it to someone else. (My car was down needing a drive shaft.) The air supspension is coool, but can take some $$$, patience, and/or electro-mechanical abilities to keep going. I'm in hopes my air ride outlasts my XT-6. Iv've been on air for 3 years now and will miss it when gone. Link to comment Share on other sites More sharing options...
