jbecker Posted January 22, 2008 Share Posted January 22, 2008 The information panel on the dash what does the "stop lamp" mean. I have a 88 gl ea82 Thanks jason Link to comment Share on other sites More sharing options...
Durania Posted January 22, 2008 Share Posted January 22, 2008 I believe it means you have a brake light out if it is illuminated while driving. Link to comment Share on other sites More sharing options...
daeron Posted January 22, 2008 Share Posted January 22, 2008 stop lamp out when lights are on: brake light out out when brakes are on: brake light out IF the bulb is good, then you have a grounding issue; possibly bad sockets, possibly a bad ground wire connection. Search "stop lamp checker," and as you go through the threads that search returns, check the bottom of the page in all of them under the "Similar Threads" feature. There are frequently good threads that the search itself misses, which are brought up by the "similar threads" feature. Link to comment Share on other sites More sharing options...
jbecker Posted January 22, 2008 Author Share Posted January 22, 2008 ok thanks Link to comment Share on other sites More sharing options...
