Quick Dash question
stop lamp out when lights are on: brake light out
out when brakes are on: brake light out
IF the bulb is good, then you have a grounding issue; possibly bad sockets, possibly a bad ground wire connection.
Search "stop lamp checker," and as you go through the threads that search returns, check the bottom of the page in all of them under the "Similar Threads" feature. There are frequently good threads that the search itself misses, which are brought up by the "similar threads" feature.
