Are these Turbo Heads
Chances are, yes. We need to see the sides of them, to see if there are oil feed/return ports and coolant ports.
EDIT: IT does look like the turbo mounting holes are there and tapped. I'm going to say yes.
Also, I didn't realize how much of an offset the intake ports were.
Somewhere on the head it should have EA82 cast into them. If it's just EA82, they're first generation, if there's a line under it, it's 2nd, if there's a box around it, it's 3rd. It's believed that they got better, but I can't remember the changes that made them better.
The Head on the right should have a tube sticking out of the big hole on its bottom left corner. The tube that's missing is for the oil return from the turbo.
+1 but is it oil or coolant? but definately a line coming out on turbo heads
