i own a 91 legacy wagon. the vehicle was vandalized is 2001 and has sat ever since. i have recently replaced all of the glass instruments and broken hardware. i am getting a code 33 and 35. i have reset the ecm and replaced the instrument gauge cluster (code 33, vehicle speed sensor) and the canister purge solenoid valve (code 35.) after resetting the computer the codes return. i suspect bad wiring or connections. can anyone tell me where the ecm is located. i would like to check my connection there and possible pinout voltage. any other help would be appreciated>
thanks
ron womack
Just a back up to Legacy777 statement.
He suggested this to me when I was having
similar issues with my 93.
Worked for me. Thanks again.
Nice picture.
For those looking for the ECU TCU
the picture is taken with the panel under the steering col.
removed and then looking at the firewall.
the speedometer is working, i have replaced the cannister purge solenoid valve. this is why i am looking towards the ecu or its connections as a possible cause. the speedo that i used to replace the one that was damaged in it's vandalism is out of a auto trans. my vehicle is a 5 speed. is it possible that they have a different signal?
thanks
ron womack
You need to use the same "kind" of ECU as you had before. The 90-91 legacies had MT and AT specific sensors. (MAF, coil pack, injectors, IAC, etc). The AT cars used a JECS ECU, while the MT cars used a Hitachi ECU. You need to use the correct brand of ECU that you had in there before. If you had a JECS, you need to use a JECS.
In 92, all the legacies went to the JECS ECU's
thanks
ron womack
The speed sensors in that vintage were just simple reed switches. ECU supplies volatge signal to one side of the switch, the speedo turns opening and closeing switch, providing and ON/OFF voltage signal to the ECU.
Sorry, I don't have any pin out pics on my computer for your car.
Did you install a used CPC solenoid? If so did you test it to see if it works?
You can plug the green test mode connectors in, KOEO, and listen to the solenoid to see if it is operating.
As said, these cars are funny about clearing any codes if there is still a problem.
thanks for all of lthe fantastic info. the cannister solenoid vavle that i used was from a salvage. i did however check it with an ohm meter and energize it to ensure operation before i installed it. as for speedo. i saved the old instrument cluster and will replace the speedo unit to see if this corrects the problem. thanks again for all of the info. i will post the results when i make the change.
thanks
ron womack
ok guys this is getting frustrating. last night i reinstalled the original instrument cluster so now my vss and ecu should be the corrrect match. while i had the car in the shop i replaced the air filter, to do this i disconnected the air flow sensor then came up with an additional code (#49 for the air flow sensor.) i disconnected the battery and let it sit overnight only to find that all three codes (33, 35, 49) are all still there. i do not think that all of these parts are bad expecially the air flow sensor since the code was never there before. is it possible that i am doing something wrong in the code reset process? i am getting tired of fighting this.
thanks again for your help
ron womack
If there is one thing wrong, none of the codes will clear.
So...........In the same area that you are finding the "read memory" connectors for pulling codes, there is a set of green connectors. These are the "test mode" connectors.
Connect the green connectors, turn the key on, engine off. You cooling fans, solenoids, relays..........will start cycling on and off.
Use a stethoscope, long screw driver to ear or something. Listen to the CPC solenoid to double check to make sure it is working.
Should be a nice sharp click on and off. If that is OK then you can turn key off. Disconnect the green connectors.
The speed sensor can be tested with the instrument cluster out of the car.
As I said it is nothing more than a reed switch. You can connect an Ohm meter across it and turn the speedo by hand. The circuit just opens and closes.
Again I have no pics on my computer of the wiring diagrams to post. My FSM is at the shop. Maybe Monday I could take some digital photos of the pertinent info and post them.
Or hopefully someone Else will post up some pics.
Since you state that the CPC solenoid is working and still have a error code for it this would mean the ECU is having a problem with that circuit at least. I would suspect the same may be true for the other codes that have just started to appear. If you verify that the solenoid is getting 12 volts while it is working using a meter and still have a code then the problem has to be with the ECU. I would also suggest checking all the input power leads going to the ECU to make sure they are ok. If those are ok, then replacing the ECU would be my next step to try and fix this trouble.
  ronwomack said:
yes i do have an audible click from the cpc solenoid. after a short drive to the store i now have added codes 42 and 51 to go along with 33, 35, and 49. this is getting ridiculous. this old girl is not far from going to the scrap heap.
:lol::grin:
Kinda funny to read but damn... you must be going nuts!!!!! :Flame:
The only other thing besides a faulty ECU that I can think of that may cause this problem is if the ECU supply power is dirty. This could be caused by a faulty alternator or bad ECU ground. If you have a digital voltmeter I would use it to test for noise on the power and grounding to the ECU. Place the meter in the AC volts function and check the voltage at the battery while revving the engine to around 2,000 RPM. See if you find any AC voltage there. You should see less than 0.2 volts there. You can also check the grounds to the ECU by measuring the voltage between the connection at the ECU and a known good ground point. If those things check ok then I would replace the ECU.
it just keeps getting better! just for fun i thought that i would replace the cpc solenoid again (i grabbed a few from the salvage yard) the new one ohms well and audibly energized. while checking for voltage from the cpc i accidently shorted out my lead on the manifold, the engine instantly died and will not start. now i can't even get it out of my shop to work on something that isn't frustrating. i'm very near hauling it off for scrap.
thanks for all of the help that you guys have offered
ron womack
You've said that twice and it doesn't make sense.
You could part it out for an EJ swap and sell the whole setup to someone here. Make some money, THEN haul off the carcass for scrap.
Hang in there, with all the good help available here we can get this going.
My info shows that there is a 22 pin connector (one of several connectors) going to the ECU. There is a yel/red wire coming from the ignition relay and it goes to pins 2 and 13 of that connector. Check for power there with the ignition ON. There is also power coming from fuse 14 on another yel/red wire to pin 15. Check that also.
you are too kind cougar. thank you for your patience. i have power at pin 15 but none at 2 and 13. which from what i can gather from my schematics would tell me that i am getting no voltage from my ign relay which is connected to my cpc solenoid. where is the ign relay locatd at?
thanks
ron womack
