Belt Driven Fan?
what's up with the gen 1 engine (belt) driven fan? My '77 manual says they were on 4WD only. What was the point of this? I ask because mine seized up, and I figure the easiest quick fix would be a smaller belt that by-passes it.
but while we are at it, does anybody have the dimensions or part #s for the bearings (I think there are 2) for the fan?
Gen 1 4WDs and Gen 1 automatics ALL came from the factory with the aux cooling/belt driven fan. (or were suppose to). Most have disapeared by now with engine repairs and transplants. After market AC kits installed also had a belt driven fan. No Gen 1 came from the factory with AC.
I'm unsure about gen 2
Todd
Todd
i think gen 1's did have the option of a/c... mine has a little toggle on it... that says a/c... and a switch spot for it... i've seen a factory set up on renaissanceman's brat...
The AC system was not installed at the factory. All the cars were "AC ready", with holes in the firewall and the air handler box capable. Of course there was the blue markings on the dash with "AC".
The kits were made by Subaru of America "specifically" for the gen 1s. There were also some other kits made by Lone Star.
The compressors were Sanden, or Mini Yorks.
As for the cooling fan, all AC installs had one. You had to have one for efficient condenser cooling.
As for "no AC/belt driven fans", the 4WDs were suppose to have them. But it might be possible that they stopped this with the stage 2s. I do believe every stage 1/ 4WD had that belt driven fan. My stage 2 4WDs had them without AC.
Todd
According to the service manuals I had for my 80 4wd wagon, the 4wd models came with the belt driven fan. But I bought mine from a import shop that had done an engine swap from jy and never got paid, it had the electric fan. so what was original and not who knows.
As far as if you dont know if your fan works or not, if it dont work you will know-my fan control thermostat went out and it would over heat when stopped in traffic caus the fan wouldnt come on.
for what it's worth i have a working belt driven fan on my 79 DL AUTO that at one time DID have A/C.
