garner Posted December 17, 2003 Share Posted December 17, 2003 I am rebuilding an EA82T and I'm having difficulty with the crank case plug. It's the plug on the bottom of the driver's side half(I think, I'm at work now and I'm going off memory). It is much like the wrist pin access plugs. I have really $%@#ed up the 14mm allen socket and am prepared to replace it once I remove the old one. Before I get crazy with the sawsall or whatver, I wonder... Can anyone tell me what's behind this plug? thanks Link to comment Share on other sites More sharing options...
NoahDL88 Posted December 17, 2003 Share Posted December 17, 2003 If its not the wrist pin access plug its the coolant plug, not necessary to remove to rebuild the engine. Link to comment Share on other sites More sharing options...
garner Posted December 17, 2003 Author Share Posted December 17, 2003 The reason I want to remove it is that I'm going to have all the parts hot tanked and I figured it would be good to get the solvent inside there. Also, If I ever need t remove the plug once the engine is built and installed, It will be even more of a PITA. If I drill through the plug in an effort to remove it, do I risk messing something up? As in, will I drill into something important? Link to comment Share on other sites More sharing options...
Nug Posted December 17, 2003 Share Posted December 17, 2003 I don't know whats behind it, but i think there's loctite on the threads. If you are gentle with a propane torch, you can soften it enough to get it out without being barberic. Link to comment Share on other sites More sharing options...
ShawnW Posted December 17, 2003 Share Posted December 17, 2003 Is that the one thats there for adding a block heater? If so you could spend the $30 or so on a block heater. Link to comment Share on other sites More sharing options...
MilesFox Posted December 18, 2003 Share Posted December 18, 2003 weld a nut to the plug, use your favorite size. that will get it off if its stripped out. the plug is steel. behind the plug is the water jacket. Link to comment Share on other sites More sharing options...
