bishop087 Posted January 26, 2008 Share Posted January 26, 2008 Hi All- I have loud heater motor in my '99 Impreza. Anybody have tips on the best way to remove it. I am hoping it just needs cleaning but I guess I won't know until I take it out. Thanks! Quote Link to comment Share on other sites More sharing options...
Skip Posted January 26, 2008 Share Posted January 26, 2008 get on you knees and well look behind the glove box There are four bolts IIRC and the plug Right there snow worries mate. shot from an older model but very much the same Hope this helps alittle. Quote Link to comment Share on other sites More sharing options...
Skip Posted January 26, 2008 Share Posted January 26, 2008 P.S. I had to remove the one in my 00 Imp every year. The field mice must have thought they were squirrels and would make camp in the yep ...... squirrel cage. ;^) Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted January 26, 2008 Share Posted January 26, 2008 get on you knees and well look behind the glove box There are four bolts IIRC and the plug Right there snow worries mate. shot from an older model but very much the same Hope this helps alittle. Looks pretty much like the same set up on the 91 Leggy that I owned. I thought the blower motor was going bad, but upon removing the motor, I found it gummed up with leaves and twigs and such. Cleaned it up, reinstalled it, and found it to work good as new. Quote Link to comment Share on other sites More sharing options...
tcspeer Posted January 27, 2008 Share Posted January 27, 2008 On my 97 Legacy wagon I had to remove the metal brace right under the glove box to have room to remove the motor. It is only about the length of the glove box with a screw or bolt at each end and very easy to remove. Quote Link to comment Share on other sites More sharing options...
Gene J Posted January 27, 2008 Share Posted January 27, 2008 See the above posts. It really is easy. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted January 28, 2008 Share Posted January 28, 2008 Yes blower is typically behind the glove box. Sometimes leaves, mouse nests, nuts, seeds, etc etc get in there. Nice pic skip! What software did you use to put the captions on there? Quote Link to comment Share on other sites More sharing options...
Skip Posted January 28, 2008 Share Posted January 28, 2008 Thanks Porc, coming from you that means a ton!! I use an antique version of "IPhoto Plus" for most of my changes. But.. I am but a mere mortal compared to you. You RULE, period, end of story ect.... Thanks for leading the way and thanks for the compliment. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted January 28, 2008 Share Posted January 28, 2008 Hm...maybe I will check out iphoto plus. I have actually just been using microsoft paint to do captions, which works ok. But on .jpg I don't see any option for quality on saves. I think it defaults to quality 70 which makes things blurry. But yours look sharp! Quote Link to comment Share on other sites More sharing options...
