Subieguy Posted January 27, 2008 Share Posted January 27, 2008 Where do I find a good kit at. I bought one for it a while back and thought it would be fine. The fingers on the pressure plate were a lot flatter than the ones on the old clutch I took out. The old ones stood up on the plate much further. Anyway this was the first clutch I have ever did. I just figured it would be ok with the new clutch I got. It works but not all that great. I had to adjust the clutch cable as far as I could and it feels like it barely grabs the clutch. It does not slip but it barely catches when I let the pedal out. Kind of sucks. So I am looking to do this again. This time with something better. Any help here would be appreciated. Thanks, Richard. Link to comment Share on other sites More sharing options...
Gloyale Posted January 27, 2008 Share Posted January 27, 2008 I had to adjust the clutch cable as far as I could and it feels like it barely grabs the clutch. It does not slip but it barely catches when I let the pedal out. Did you tighten the cable or loosen it? Is the action at the very top of the pedal or at the bottom? If you have the cable tight, it will be pulling off the clutch all the time. Not good for the clutch or throw out bearing. You need to loosen the cable to the point where there is slack on it. You should be able to wiggle the clutch fork abit. And the pedal should have abit of free travel at the top. The action should be right in the middle of the pedal stroke. Link to comment Share on other sites More sharing options...
aba4430 Posted January 28, 2008 Share Posted January 28, 2008 Does this help you? http://www.subaruparts.com/catalog/?section=759#1403 Link to comment Share on other sites More sharing options...
Subieguy Posted January 29, 2008 Author Share Posted January 29, 2008 Yeah it does help. Too bad I didn't stay with a OEM clutch in the first place. Would have saved myself a lot of trouble. Does this help you?http://www.subaruparts.com/catalog/?section=759#1403 Link to comment Share on other sites More sharing options...
