hardtail_pride Posted January 28, 2008 Share Posted January 28, 2008 Ok so i have a 92 loyale with the EA82 i believe and i have been replacing all the vacuum lines and now my cruise control works which is great! I kinda throttles on and off but keeps the speed i set just fine, so i was wondering if that is normal or if it should be a more constant throttle'ing? Thanks Link to comment Share on other sites More sharing options...
mikeshoup Posted January 28, 2008 Share Posted January 28, 2008 The cruise control on my 88 GL felt the same. That kinda feathering feel almost. I don't know if that's how it normally worked, or if its due to old age. Link to comment Share on other sites More sharing options...
Skip Posted January 28, 2008 Share Posted January 28, 2008 Please see this post esp #18 by Gloyale verify you have enough vacuum http://www.ultimatesubaru.org/forum/showthread.php?t=78136&highlight=cruise+control Link to comment Share on other sites More sharing options...
mfolsom Posted February 13, 2008 Share Posted February 13, 2008 Sorry for reviving an old thread but I wanted to share something that didn't need it's own. After a year, I finally got my 85 GL wagon back on the road. The first few test drives on the rebuilt engine were OK and a few bugs had to be worked out on vacuum lines. Before the engine RR everything worked including cruise control. During one of my trips to work I tried the cruise and sadly it did not work. On the way back I tried it again and at first it didn't work but I kept trying and got it to come on. That was the last time it worked until last night. I had the under dash panels off to add wiring for an electric cooling fan so I crawled under there to look at the dealer added cruise control stuff. I noticed the switch for the clutch pedal cruise disengage was barely pushed so I adjusted it and walla, a test drive proved I found the problem. Now everything works on my "little old man" again. Link to comment Share on other sites More sharing options...
