Joey Joe Posted January 30, 2008 Share Posted January 30, 2008 The button is broken and I broke a wire off so my plan is to re wire it to a switch button but I cant tell which ones are ground and positive and negative there are three wires red yellow and white. Any one know Link to comment Share on other sites More sharing options...
Gloyale Posted January 30, 2008 Share Posted January 30, 2008 None of them are ground 1 should have 12v with key on. the other two are the signal wires that operate the 2 solenoids that control opertaion of 4wd. Signal to one = solenoid to activate 4wd to the other = solenoid to disengage 4wd Use a MM or test light to find the constant 12v Then use trail and error to determine which is which for the others. If you REEEEEAAAAALLLLLY need wire colors I'll check for ya tommorow. This is for Manual trans. If this is an automatic I can't recall excactly the setup. Again I'll check up tommorow Link to comment Share on other sites More sharing options...
Joey Joe Posted January 30, 2008 Author Share Posted January 30, 2008 Should be enough info to get it fixed Link to comment Share on other sites More sharing options...
Skip Posted January 30, 2008 Share Posted January 30, 2008 Gloyale is spot on with his description the automatics work the same way. Remember you will need a SPDT (Single Pole Double Throw) switch. Link to comment Share on other sites More sharing options...
TheBush Posted February 4, 2008 Share Posted February 4, 2008 I was wondering if you could tell me which wire colors are which. Mine is a 86 but has 4wd push button. Link to comment Share on other sites More sharing options...
Skip Posted February 4, 2008 Share Posted February 4, 2008 Howdy Bush, you might consider telling what type tranny you have (manual/auto) and or creating your own post Link to comment Share on other sites More sharing options...
TheBush Posted February 4, 2008 Share Posted February 4, 2008 Hi Skip, Thanks. I have 5SPD MT. Sorry, I saw the earlier post where it said just for manuals so yea. I appreciate the help though! Link to comment Share on other sites More sharing options...
TheBush Posted February 7, 2008 Share Posted February 7, 2008 Well.... I did it myself. If your hooking it up to a single pole, double throw switch (which you must), the white wire is the one in the middle. Works well! Link to comment Share on other sites More sharing options...
