buzzcon Posted January 30, 2008 Share Posted January 30, 2008 When I engage the switch for the 4wd, on my 88 ea82t wagon, it doesn't engage right away. Then, when I turn off the switch, it doesn't disengage right away. Any ideas on what's causing that? (easy fix?) Thanks ~Myles~ Link to comment Share on other sites More sharing options...
Skip Posted January 30, 2008 Share Posted January 30, 2008 Myles, If all your tires are the same diameter. There is nothing wrong, they all take a few revolutions to engage/ diengage. You can't use it on unslick surfaces, you know that right? Link to comment Share on other sites More sharing options...
mikeshoup Posted January 30, 2008 Share Posted January 30, 2008 Yeah, its not instant on or anything. It'll help if you make sure the vacuum line running up to the solenoids and the lines running off of the solenoids are in good shape. Also, the engine has to be under vacuum for it to work. So the pedal needs to not be depressed, or only slightly depressed. Link to comment Share on other sites More sharing options...
buzzcon Posted January 31, 2008 Author Share Posted January 31, 2008 Yeah, its not instant on or anything. It'll help if you make sure the vacuum line running up to the solenoids and the lines running off of the solenoids are in good shape. Also, the engine has to be under vacuum for it to work. So the pedal needs to not be depressed, or only slightly depressed. Thanks, I'll check out the vacume lines. My wife's '86 sedan engages and disengages immediately. My CJ7 engaged and disengaged immediately, too. So does my F150. Could I be having solenoid problems or should I just not be concerned about it? Link to comment Share on other sites More sharing options...
MilesFox Posted January 31, 2008 Share Posted January 31, 2008 the car will have to be moving to engage, disengage. also, the steering wheel should be straight, dont use the button while turning! it's not a vac problem if the 4wd is in fact working. the vacuum controls a diaphragm thet pushes or pulls on a rod to actuate the 4wd Link to comment Share on other sites More sharing options...
Skip Posted January 31, 2008 Share Posted January 31, 2008 Exactly like Miles said. I would add the vacuum needed is "stored" in a canister on the shelf behind the pass side strut. If it's check valve goes bad you will not "store" vacuum. An easy indication of this is the HVAC output vents change when you pull a long hill or accelerate. (the HVAC's vacuum controlled doors use the same storage container.) Be sure to Check the tire manufacturers/sizes and pressures. Do not use 4wd on surfaces that have good traction. Link to comment Share on other sites More sharing options...
