I plan to fix this with a Subaru thermostat soon, but I'm curious about the technical details...
We had an aftermarket thermostat put in at a timing belt change. Now the temp. gauge runs up to a hotter point than I ever recall before, but it eventually settles down to where it usually runs. It never seems dangerously hot, but hotter than before.
Does this mean the thermostat is sticking open or sticking shut? (Or, of course, neither... :))
Dave we do not know what car/engine you are talking about
but
some aftermarket T-stats will fit in upside down.
This may cause what you describe, esp in an EJ engine
with the T-stat on the block side of the lower hose.
"Coils to the block so it won't get too hot"
You are doing the right thing getting an OEM T-stat
See Porc73's pictures of the difference.
After seeing Porcupine's most excellent pictures.
I had to see if it is true that a
junk aftermarket T-stat
I had the parts on the bench so I took a look
Fit fine, but will NOT last a long time
Looking at those last photos, the "jiggle pin" is also mounted incorrectly by the thermostat manufacturer.
(Even though that way round seems right to me, can't understand why Subaru put the pin the other way round. Still, Subaru engineers most often seem to know what they're doing, so there must be a good reason!)
Isn't that little vent on the rim of the OEM stat (the above mention jiggle pin) to help in purging any air in the system? The after markets don't have that. Soobs are hard enough to vent with the OEM stats. I would think some of the problems with the after markets are due to air pockets.
both have jiggle pins
and you are correct on their purpose
I believe what Setright refers to is
the aftermarket t stat pin
closes when mounted in a EJ series engine.
This due no doubt to the upside down
mounting.
Very astute observation I must say.
