Caboobaroo Posted January 31, 2008 Share Posted January 31, 2008 So today I started the fun of stuffing my set of '05 STi seats into my car. Actually not too bad considering I didn't know what to expect. Pic will come when I do the driver seat since I was too busy trying to get the passenger side to work. I started off by removing the seat rails from both the RX seat and the STi seat. Since the RX seat rails are bolted vertically to the floor and the STi rails are bolted parallel to the floor of the car, I had to make some tabs that I later welded to the RX seat rails. I made 4 tabs that would be welded to the RX rails but of course, had to take the seat in and out a few times in order to get the height right, along with making it level. The seat back is much taller then the RX seat but the base only sits maybe 1/2" higher then stock. Had one of the guys from work try it out (6'5", 250lbs.) and he had to recline the seat back pretty far but said it didn't feel like it was really sitting too high. Also discovered that in order to do this to the driver seat, you need the seat rails from a non GL-10 or RX seat, you know, the one with the height adjuster that telescopes from the side. It directly connects to the seat rails and well, isn't needed. Granted you can keep it but there's no real point in keeping it since the seat will be the 1/2" higher and the back of the seat might actually hit the roof of the car. Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 31, 2008 Author Share Posted January 31, 2008 Pics of passenger side seat in car! You can see one of the brackets I made at the very left of this pic Comparison between RX and STi seats Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted January 31, 2008 Share Posted January 31, 2008 walk away from the pc and pictures appear..lol awesome so right! Kaz Link to comment Share on other sites More sharing options...
mykingcrab Posted January 31, 2008 Share Posted January 31, 2008 That looks sweet Russ. :burnout: very similar style. p.s. what can you tell me about this mistery,since I see we have the same shifters? http://www.ultimatesubaru.org/forum/showthread.php?t=84646 Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted January 31, 2008 Share Posted January 31, 2008 Nice Russ! The fitment of your sti seats looks pretty similar to my wrx seats in my hatch. I know that after you have the seats in there it will be like driving a completely different car. Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 31, 2008 Author Share Posted January 31, 2008 mykingcrab said: That looks sweet Russ. :burnout: very similar style.p.s. what can you tell me about this mistery,since I see we have the same shifters? http://www.ultimatesubaru.org/forum/showthread.php?t=84646 Heh so firstly, you need to know my '87 "RX STi" is made up of a few cars. Ranging from '85-'96 is more like the span. The shift knob you see for the 4wd selector is on a short throw (and cut down) FT4wd shift linkage for the '87 RX tranny. The knob is however from a '85 GL-10 turbo sedan with dual range 5-speed (same car the checkerboard seats are from). It is however cut down about 4" or so. Suspension/brakes is made up of '91 XT6, '89 RX, and '96 Impreza pieces. Engine is from another '87 IIRC and well, you get the idea. Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 31, 2008 Author Share Posted January 31, 2008 PoorManzImpreza said: walk away from the pc and pictures appear..lolawesome so right! Kaz Yeah I was like "TTIWWOP!" to myself so I went out and took some. Thanks for the compliments guys, now I just gotta get the other one in there:rolleyes: Link to comment Share on other sites More sharing options...
monstaru Posted January 31, 2008 Share Posted January 31, 2008 mmmmm....comfy Link to comment Share on other sites More sharing options...
mykingcrab Posted February 1, 2008 Share Posted February 1, 2008 Caboobaroo said: Heh so firstly, you need to know my '87 "RX STi" is made up of a few cars. Ranging from '85-'96 is more like the span. The shift knob you see for the 4wd selector is on a short throw (and cut down) FT4wd shift linkage for the '87 RX tranny. The knob is however from a '85 GL-10 turbo sedan with dual range 5-speed (same car the checkerboard seats are from). It is however cut down about 4" or so. Suspension/brakes is made up of '91 XT6, '89 RX, and '96 Impreza pieces. Engine is from another '87 IIRC and well, you get the idea. Ok gottcha!! thnx. Link to comment Share on other sites More sharing options...
Caboobaroo Posted February 1, 2008 Author Share Posted February 1, 2008 So Webshots is down currently but once it comes back online, my pics will reappear. If not, I'll edit to make them show up again. Link to comment Share on other sites More sharing options...
kingbobdole Posted February 1, 2008 Share Posted February 1, 2008 ACK! no pics! photobucket FTW! Link to comment Share on other sites More sharing options...
Caboobaroo Posted February 1, 2008 Author Share Posted February 1, 2008 Pics now worky again:banana: Link to comment Share on other sites More sharing options...
kingbobdole Posted February 2, 2008 Share Posted February 2, 2008 Didja get the driver's into the car yet? My scheme was to cut the "feet" offa the stock rails and weld them to the sti rails. lika so But then they were to high for my XT so I cut into the car where the seat bolted and lowered that... it was quite the pain..... Link to comment Share on other sites More sharing options...
Caboobaroo Posted February 3, 2008 Author Share Posted February 3, 2008 Not yet, I'm still trying to get a set of seat rails from a non height adjustment driver seat. It'll go in the same way as the passenger side though. I found that doing it this way made it sit lower then if I tried to modify the STi rails instead. Link to comment Share on other sites More sharing options...
Durania Posted February 4, 2008 Share Posted February 4, 2008 How much did the seats run you? Link to comment Share on other sites More sharing options...
Caboobaroo Posted February 5, 2008 Author Share Posted February 5, 2008 5x more then I originally bought the car for:-p $540 after everything (including gas and food) to pick them up Link to comment Share on other sites More sharing options...
kingbobdole Posted February 6, 2008 Share Posted February 6, 2008 Caboobaroo said: 5x more then I originally bought the car for:-p $540 after everything (including gas and food) to pick them up sorry.... you got raped! I paid like $200 shipped for my one a few years ago. Link to comment Share on other sites More sharing options...
Caboobaroo Posted February 6, 2008 Author Share Posted February 6, 2008 Oh I went and got other parts as well so the trip was worth more then I had originally planned. That and I didn't have to drive:banana: Link to comment Share on other sites More sharing options...
