ea82 wagon troubles
First thing I'd check would be tire pressure, then the lugnuts, then I'd jack it up and check the tie-rod ends, ball joints and struts - then I'd check where the front suspension bolts to the underside of the car and make sure nothing came loose (the FS is just bolted to the underside of the pan - 17 or 19mm bolt heads IIRC). I know one thing - I wouldn't drive it again until I figured out and resolved the problem!
I jacked it up and everything seemed to be okay, I put some air in my tire(i think my problem) and tightened the bolts up, I think it just seemed really bad because I had around a thousand pounds worth of people in my car. We'll see if something comes up :). I'm actually pretty good on rust, surprisingly. Thanks for your input guys.
