NorseKode Posted December 18, 2003 Share Posted December 18, 2003 ea82 '91 loyale 4wd 5spd TBI I've looked for vacuum leaks everywhere and replaced all vacuum hose. No change. Cleaned up the IAC with BrakeKlean. No change. Checked the IAC assembly with 12V and some jumper wires. Seems to work just fine. Freakin' idle is still 1300 when warm. Temp guage never climbs aboce the "C". Also, at idle, the throttle cable is very slack. At least an inch of pedal travel before throttle is pulled back. Is this normal? Kalo Link to comment Share on other sites More sharing options...
GLCraig Posted December 18, 2003 Share Posted December 18, 2003 It appears that the temp sensor(s) or the thermostat are bad. If the ECU thinks the engine is still cold it will maintain fast idle. Link to comment Share on other sites More sharing options...
LuckDrgnAeon Posted November 30, 2006 Share Posted November 30, 2006 I'm having the same problem, and I've change the thermostat. What Temp sensor do you mean? Link to comment Share on other sites More sharing options...
Phizinza Posted November 30, 2006 Share Posted November 30, 2006 Timming can change idle speed. Check your timming? Or is that computer controlled on SPFI EA82's? Link to comment Share on other sites More sharing options...
