shortlid Posted February 2, 2008 Share Posted February 2, 2008 Do any Foresters come factory with LSD diffs in them? Link to comment Share on other sites More sharing options...
sea#3 Posted February 2, 2008 Share Posted February 2, 2008 Yup 2000-2001 Forester S ,then they don't show in the manuals till 05 .but that doesn't mean they didnt have them in between those years SEA#3 Link to comment Share on other sites More sharing options...
Hondasucks Posted February 2, 2008 Share Posted February 2, 2008 Some outbacks have LSD too, but I have yet to see one with a sticker on the diff, best way is just turn the axle on one side and if the other side turns the same direction, it's LSD. I don't know what outbacks had it, I just know that a lot of the ones that come into my work (Subaru dealer) when I have it up on the lift and I'm rotating the wheel to check the brakes and axle boots in the rear, both rear tires turn the same direction. Link to comment Share on other sites More sharing options...
shortlid Posted February 2, 2008 Author Share Posted February 2, 2008 Hondasucks said: Some outbacks have LSD too, but I have yet to see one with a sticker on the diff, best way is just turn the axle on one side and if the other side turns the same direction, it's LSD. I don't know what outbacks had it, I just know that a lot of the ones that come into my work (Subaru dealer) when I have it up on the lift and I'm rotating the wheel to check the brakes and axle boots in the rear, both rear tires turn the same direction. Yep my Mom's '03Legacy GT sedan has a LSD rear end. Link to comment Share on other sites More sharing options...
rude Posted February 5, 2008 Share Posted February 5, 2008 I have 01 "S" with factory everything, including LSD. Is there anything you want to know about it? I think I have the orginal window sticker, somewhere. Link to comment Share on other sites More sharing options...
keltik Posted February 5, 2008 Share Posted February 5, 2008 Sorry to drag this a little off topic - but whats a definitive test for a rear LSD? Mine has no sticker on it and im curious to know what ive got. Link to comment Share on other sites More sharing options...
Durania Posted February 5, 2008 Share Posted February 5, 2008 keltik said: Sorry to drag this a little off topic - but whats a definitive test for a rear LSD? Mine has no sticker on it and im curious to know what ive got. It involves jacking up the rear of the car and rotating one of the wheels by hand. If the opposite wheel turns in the same direction the one by hand is being turned, then you have a LSD. If it turns in the opposite direction (backwards) then you have an open differential. Link to comment Share on other sites More sharing options...
keltik Posted February 5, 2008 Share Posted February 5, 2008 What i mean is with my car being awd...im thinking both wheels may just turn in the same direction and rotate the driveshaft. Ive seen quite a few open diffs with enough drag in them to do this - doesnt take much. Link to comment Share on other sites More sharing options...
edrach Posted February 5, 2008 Share Posted February 5, 2008 keltik said: What i mean is with my car being awd...im thinking both wheels may just turn in the same direction and rotate the driveshaft. Ive seen quite a few open diffs with enough drag in them to do this - doesnt take much.Durania gave you the correct method of testing....doesn't matter whether it's AWD or not. Link to comment Share on other sites More sharing options...
keltik Posted February 5, 2008 Share Posted February 5, 2008 Cheers il give it a shot tomorrow. Link to comment Share on other sites More sharing options...
ferret Posted February 5, 2008 Share Posted February 5, 2008 USDM 98-08 only the base or L Forester DOES NOT have a rear LSD. It is standard on all S, XS, Premium and Turbo models. That all changes in 2009 Forester line with VDC standard on all models. 1 Link to comment Share on other sites More sharing options...
shortlid Posted February 5, 2008 Author Share Posted February 5, 2008 ferret said: USDM 98-08 only the base or L Forester DOES NOT have a rear LSD. It is standard on all S, XS, Premium and Turbo models. That all changes in 2009 Forester line with VDC standard on all models. Great info thanks! Link to comment Share on other sites More sharing options...
Spiffy Posted February 5, 2008 Share Posted February 5, 2008 shortlid said: Do any Foresters come factory with LSD diffs in them? guess you've already got your answers, but... I shopped for a Forester with an LSD in mind as well... I referenced cars101.com to see which ones had the LSD... I ended up with a 2000 Forester S... lots of fun little comfort options... I think if you get one a year or two newer you can also get the moonroof option... but I didn't want to spend the extra money at the time... --Spiffy Link to comment Share on other sites More sharing options...
edrach Posted February 5, 2008 Share Posted February 5, 2008 ferret said: USDM 98-08 only the base or L Forester DOES NOT have a rear LSD. It is standard on all S, XS, Premium and Turbo models. That all changes in 2009 Forester line with VDC standard on all models. That would be great news if accurate. Looks like I'll be jacking up the rear wheels on our '99 Model S! Link to comment Share on other sites More sharing options...
wvraid6 Posted December 25, 2013 Share Posted December 25, 2013 On 2/5/2008 at 12:09 PM, ferret said: USDM 98-08 only the base or L Forester DOES NOT have a rear LSD. It is standard on all S, XS, Premium and Turbo models. That all changes in 2009 Forester line with VDC standard on all models. thanks = good info Link to comment Share on other sites More sharing options...
