WoodsWagon Posted February 3, 2008 Share Posted February 3, 2008 So it's getting to be inspection time again. The stock fenders that I cut to fit the larger tires are getting rusty, and the fenders never covered the tires, a failing offence. I spotted the solution in the junkyard: a 1994 Cavalier. Not the actual car but I would support cutting this one up too. So I cut out the fender flare, and a strip going down to the rocker to replace the rotted out area. Welded them up into place and they look good. A bit of grinding and some black spray paint, and it'll be perfect. Link to comment Share on other sites More sharing options...
Phizinza Posted February 3, 2008 Share Posted February 3, 2008 Weld looks alright.. What did you weld it with? I'm welding body panels at the moment for a current project and keep blowing holes in things haha. Link to comment Share on other sites More sharing options...
slideshow86 Posted February 3, 2008 Share Posted February 3, 2008 Weld looks alright.. What did you weld it with? I'm welding body panels at the moment for a current project and keep blowing holes in things haha. Try less heat or less time spent on the surface your welding. Bounce around alot to keep it from warping. Like do 2in the move to the other side and do 2in, Keeping it as cool as possible. Try just doing a bunch of spot welds, not laying a constant bead. Hope this helps. Link to comment Share on other sites More sharing options...
WoodsWagon Posted February 3, 2008 Author Share Posted February 3, 2008 Millermatic 185, setting 1, 20" wire feed speed. Straight argon. Welds looked a lot better thursday when I did them, the salt water from the road has already rusted them up good. I tacked it down with a lot of spot welds, then did 1" beads switching from spot to spot. Don't stay too long, or work in one area too much, the whole fender will warp and you will be in suckageville. I'll have to do a bit of grinding to level the beads out before I paint, some of the spot welds stick out a bit. The dents and puckers were already in that fender. I rubbed it pretty good on a tree chasing a cat on the property. Smashed the corner light too, so I had to replace that. Take your time, and grind the paint off where you're welding. Clean is a must. Oh, and how can you even tell from that picture? My camer sucks rump roast, it can't focus, and that picture is pretty blurry. Link to comment Share on other sites More sharing options...
Phizinza Posted February 3, 2008 Share Posted February 3, 2008 Oh, and how can you even tell from that picture? My camer sucks rump roast, it can't focus, and that picture is pretty blurry. Cross your eyes and it looks clear!!.. Nah, that doesn't work.. really it doesn't. Its just that I can't see holes in it, and it looks like one continuous weld. Link to comment Share on other sites More sharing options...
newsoobdude Posted February 4, 2008 Share Posted February 4, 2008 Man! That's a great idea and looks good. Need to get a pic of the whole side of the car also. What size tires are you running? Link to comment Share on other sites More sharing options...
mykingcrab Posted February 4, 2008 Share Posted February 4, 2008 great job!!!!!!!!!!!! :headbang: Link to comment Share on other sites More sharing options...
michael appel Posted February 5, 2008 Share Posted February 5, 2008 wow that is good work you did very clean and custom Link to comment Share on other sites More sharing options...
ivantruckman Posted February 6, 2008 Share Posted February 6, 2008 Hmmmm. thats got me thinking, i wonder if you can find any plastic flairs in a J Y. , we dont have any inspection in michigan , but im getting tired of slinging mud all over Link to comment Share on other sites More sharing options...
