xoomer Posted February 6, 2008 Share Posted February 6, 2008 Ok, This sounds wierd... but on my head liner in the back has a drip coming out of it on both sides.. My window is fine and I don't see any rust. I'm wondering if there is anywere this leak might be coming from other than the window... cause The cheapest I can get to pull and reseal is like $200 for my back window... Its getting anoying. Quote Link to comment Share on other sites More sharing options...
markjw Posted February 6, 2008 Share Posted February 6, 2008 I've seen the fasteners for the roof rack leak and eventually ruin the head liner. Hope thats not your situation. Quote Link to comment Share on other sites More sharing options...
Bucky92 Posted February 6, 2008 Share Posted February 6, 2008 Ok, This sounds wierd... but on my head liner in the back has a drip coming out of it on both sides.. My window is fine and I don't see any rust. I'm wondering if there is anywere this leak might be coming from other than the window... cause The cheapest I can get to pull and reseal is like $200 for my back window... Its getting anoying. You dont have to have the window pulled..just do what I told you on the XT board..Over the years the seals dry up..shrink..and you get window leaks..common problem with XT6s..also the trim will rattle. This is really no big deal..Easy fix for under $10 Quote Link to comment Share on other sites More sharing options...
