Just bought a 99 Leg .. Tranny question...
Hello again! We just bought a 99 Legacy Wagon, AWD, 83k miles, Auto and loaded up very nicely. Noticed today that the car doesn't like to stay in 4th gear. It will go into fourth about when you'd expect it to, but when you let off, even on level ground or going downhill, it will shift back into 3rd. In fact, I THINK it shifted down into 2nd from 3rd once at even lower speeds. It's pretty annoying, but doesn't really hurt the drivability.
Any ideas on this issue? Please don't say the word 'toast'.
ALSO.... while looking for info on the tranny issue, I say several comments about tranny issues and head gasket issues on 99's. What wonders do I have to look forward to with this car. We named him 'Jasper' by the way. He just looks like a Jasper.
ALSO ALSO...... We will be selling our beloved 'Blubaru'... a 90 Legacy Wagon, auto, 155k miles, runs okay, lots of little stuff here and there and some fairly significant torque bind. Anyone interested? Asking $800.
--Mike
As far as determining the shifting pattern.... I waited until I felt it down shift, going down a hill, and then pulled the shifter back into D3, which resulted in no change of rpm or gear. Then I pushed the shifter back into D, and it immediately shifted up into 4th and the rpm dropped as you would expect. The problem then repeated itself shortly thereafter.
I have not had an opportunity to see exactly at what speeds it does what. I was on a typically twisty WV road, so I was likely not over 55 or 60 at most... but still... solidly over 40 or 45.
M
yeah at 40 or 45 it will def. down shift to 3rd and if there is an incline or so at 40 it will even downshift to 2nd... i dont think there is anything worng with your tranny... but change the fluid and put some lucas trans fix in it just in case... i doubt at 83k miles the tranny is toast...
let us know what happens
:lol: Yah that could be that somewhat silly 'hill descent assist', where if you are going downhill (ie no throttle) over a certain speed and even touch the brake, it automatically downshifts to 3rd to help you slow down. Another case of the machine thinking it's smarter than you.
I agree, hill descendt feature. My 99 Outback did it and it drove me to distraction till I found it was "normal" I did get it to lessen quite a bit when I drained the tranny fluid a few times and added the Lucas product. Also, try not braking when descending hills. Not being funny, I mean anticipate and slow before that feature kicks in whenever possible. Bob
Yes... the car does have cruise control. Would that cause/add to this issue?
I thought I remembered something about a decent assist. In fact, I noticed at least once or twice that the downshift occured when I tapped the brake pedal... however, it certainly happened at other times as well. That left me looking for a switch/button/magic chant to turn the damn feature off. (There's no owner's manual in the car.) Let me guess. It's a 'stay on for the life of the car' kind of feature!
M...
  Rooster2 said:
  njdrsubaru said:
if it is an L or 30th anniversary edition, it is definetely a 2.2
Hmmmm........learned something new. I thought all 99 Leggys had the 2.5 phase one motor when new. Surprised to read that your car has the 2.2 motor.
:banana: :banana:
i'm not the only one.
nipper
  njdrsubaru said:
and dont forget the brightons had 2.2s too :banana: :banana: :clap:
2000 was the last year for 2.2L engines in legacys and 2001 was the last year for the impreza. from there out it's all 2.5s in all the legacy / outbacks and 2.0 or 2.5 for imprezas.
the 2.0L in the impreza seems like a step backwards, was that a turbo engine?
Since we are on the subject of MY's with 2.2, I have a question that I hope doesn't steal the topic of the thread.Why did Subaru ditch the 2.2? The obvious answer is the 2.5,but now that we are seeing so many issues with the 2.5 why doesn't Subaru bring back the tried and tested? Any ideas?
For the same reason you wont see the 1.6 or 1.8 make a comeback.
We like to go fast quickly, and we als like our cars loaded down with every power gizmo you can think of, and quiet. It all adds weight.
nipper
Quick update and a big THANK YOU!
Had the tranny flushed and a new filter put on our 99 Leg. yesterday. It now drives like a different car! We had it done a Monro, fluid only, no detergent. Cost us about $120 with the new filter. The car is smooth and quiet and stays in 4th gear at speed! The mechanic said the fluid was dirty, but it smelled more "old" than "burnt". I'm hoping that's a good thing.
Also... we had a belt squeal. I came back to ultimatesubaru.org and searched the archives, learning from everyone else's posts. Took a look at the car and sure enough, whoever last changed the belts forgot to re-tighten the lock nut. Tightened it all up... no squeal!
So ... a great big thank you to Nipper, OB99W, njdrsubaru and everyone else who has helped a novice like me to diagnose and fix my own subaru! This forum is an AMAZING resource and I direct everyone I know who owns a soobie to check it out! :banana:
