nw_david Posted February 7, 2008 Share Posted February 7, 2008 just wondering if anyone has any experience with putting lights on their rig. pictures or suggestion would be awesome... heres what i've got so far in photoshop added lights + tint Link to comment Share on other sites More sharing options...
TeamCF Posted February 8, 2008 Share Posted February 8, 2008 Looks good. I know lots of people will put the basket style roof racks on and just bolt the lights on there. Myself, I just drilled holes in the roof and put a couple KC daylighter style lights right on. With lots of silicone for leaks. I seem to have very little vibration on trails at night. even though they are just mounted to the sheetmetal. I plan on mounting them to a rack when I get one though and plugging the holes. Pretty sure there's a pic in my gallery. Link to comment Share on other sites More sharing options...
matts87glsedan Posted February 8, 2008 Share Posted February 8, 2008 how bout some squares under mounted on the top rail of your bumper... just a thought. i'm putting two 100w rounds on my 2x3 bumper right now. but i wasnt thinking when i built it and the lights have to stick out front of it because of lack of clearance to the hood.. grr. sorry no pics... yet. Link to comment Share on other sites More sharing options...
The Beast I Drive Posted February 8, 2008 Share Posted February 8, 2008 Here's mine when I first got it, it was for a fullsize Bronco, I cut 10 inches off it I think, I bolted it to the roof and I sealed everything eith silicone, no leaks so far Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted February 8, 2008 Share Posted February 8, 2008 I'd be worried about low clearance areas. I'm also working on light bars. Link to comment Share on other sites More sharing options...
Rooinater Posted February 9, 2008 Share Posted February 9, 2008 if your going to bother with a light bar make sure the lights are well protected. I wouldn't suggest one, it leaves the lights vulnerable to branches and a small amounts of light in the car can be bothersome also. just mount them protected behind a grill guard. Link to comment Share on other sites More sharing options...
The Beast I Drive Posted February 9, 2008 Share Posted February 9, 2008 i never get light inside my car with my lights, they do just fine on the roof as long as you dont have t tops or a sunroof Link to comment Share on other sites More sharing options...
nw_david Posted February 9, 2008 Author Share Posted February 9, 2008 i was looking up that light stuff again and saw that once you hit like 6 or so 100 watt lights you run into problems with killing alternators and stuff. have any of you guys ran into that kind of stuff? oh yeah that bar looks sick "The Beast I Drive" Link to comment Share on other sites More sharing options...
Numbchux Posted February 9, 2008 Share Posted February 9, 2008 just make sure you don't mount them too far forward so you don't get glare on the windsheild. here's the setup I had on my blue wagon (tabs welded onto the ends of my Yakima crossbars): sweet picture, but the lights are too far forward, notice how they light up the windshield. which means that the light will reflect off any dirt thats on the glass, and cause a glare. daylight pic of those: and yes, I did break these off on the trail once :-\ much simpler method. the PO of the black wagon that I had just drilled 2 holes in the Thule roof rack bars (square): Link to comment Share on other sites More sharing options...
backwoodsboy Posted February 9, 2008 Share Posted February 9, 2008 Thats a nice looking rack, but if I had a suggestion, I would say to reverse the slant on the guard piece in front of the lights. It looks hot.... but I can just SEE that thing with about 20 LBS of leaves and branches wadded in there against the roof after a healthy fire trail run. My .02 Link to comment Share on other sites More sharing options...
Skip Posted February 9, 2008 Share Posted February 9, 2008 your title says "rack so I guess this doesn't count? The aux (2 Hella, 2 KC)all have 100 w lamps wired via relays to come on with the high beams. (road car sorry) I have an XT6 alt, and have rewired the old below bumper turnsignals to the corner lights beside the factory head lights (Osram ultrvisions) Here is one of my Brats that can play off road 'Yota" truck bar by Jackman (I believe) modified to fit with a blue tip hotwrench Link to comment Share on other sites More sharing options...
nw_david Posted February 9, 2008 Author Share Posted February 9, 2008 your title says "rack so I guess this doesn't count? The aux (2 Hella, 2 KC)all have 100 w lamps wired via relays to come on with the high beams. (road car sorry) I have an XT6 alt, and have rewired the old below bumper turnsignals to the corner lights beside the factory head lights (Osram ultrvisions) thats a sick setup. what do you think is better, 2 normal 60amp alternators or a single xt6 90amp one? Link to comment Share on other sites More sharing options...
Skip Posted February 9, 2008 Share Posted February 9, 2008 Howdy David, thanks for the compl. I've never seen a duel alt setup, sounds kewl. I have never had any problems with the XT6 alt. (about a year and a half) I was eating alts to the tune of one every 6 mo. before the swap. here are a couple "on the bench" in my shop Please note: There is a swap to a high amp GM alt. Some like it better as the GM alt is an easy find. Link to comment Share on other sites More sharing options...
backwoodsboy Posted February 9, 2008 Share Posted February 9, 2008 Skip, I like your "shop chair" Link to comment Share on other sites More sharing options...
Skip Posted February 9, 2008 Share Posted February 9, 2008 Thanks, John Good Eye!! 87 GL-10 I've posted this pict quite a few times hope folks are not getting tired of seeing it. Link to comment Share on other sites More sharing options...
nw_david Posted February 9, 2008 Author Share Posted February 9, 2008 for the duel setup i've always thought i could rig up another one in place of my a/c that i don't even use anymore. it seems like it'd be cheaper than an xt6 alt when remanufactured 60amp ones go for like $50 each on ebay. Link to comment Share on other sites More sharing options...
GoldieOldie Posted February 10, 2008 Share Posted February 10, 2008 How easy is it to swap in the xt6 or GM alt? does the xt6 just drop in? Link to comment Share on other sites More sharing options...
monstaru Posted February 10, 2008 Share Posted February 10, 2008 read this for all info on alts. you could ever want.cheers, brian the search function is awesome:grin: http://www.ultimatesubaru.org/forum/showthread.php?t=24227&highlight=alternator Link to comment Share on other sites More sharing options...
Skip Posted February 10, 2008 Share Posted February 10, 2008 way to use the search function Monsta!! Excellent link for all concerned!! Link to comment Share on other sites More sharing options...
DrKrazy Posted February 10, 2008 Share Posted February 10, 2008 Mine is similar to most people's rack setup. A couple of cheap crossbars, with an XT spare tire rack mounted between them to hold my spare tire. 60 watt yellows up top, 100 watt white's on the bumper. My experience with alts is killing a couple original 60 amp ones. Swapped to a 100 amp GM alt, ended up killing that also, needed to get a smaller pulley on it as it was worse than then stock for me at idle. Then I swapped to a dual battery setup and haven't had an issue. Link to comment Share on other sites More sharing options...
Andyjo Posted February 10, 2008 Share Posted February 10, 2008 yes Link to comment Share on other sites More sharing options...
Skip Posted February 10, 2008 Share Posted February 10, 2008 nice shot Andy!! "Spelunkers do it deeper" I know most of these are for "Off Road" But here in PA, lights on the roof must be run with the covers on when driven on the highway. Is this a wive's tale? and/or do other states have this rule? Link to comment Share on other sites More sharing options...
r_kirky Posted February 10, 2008 Share Posted February 10, 2008 Link to comment Share on other sites More sharing options...
nw_david Posted February 10, 2008 Author Share Posted February 10, 2008 Please note: There is a swap to a high amp GM alt. Some like it better as the GM alt is an easy find. that gm one seems like the way to go thanks for informing me http://random.fjeer.us/altswap.html ****Edit**** Thanks monstaru for the link Link to comment Share on other sites More sharing options...
Skip Posted February 10, 2008 Share Posted February 10, 2008 my pleasure David, glad you found it good link, it is by the gentleman who started the thread MonstaRu linked to in post #18 "mo powr' to ya" The duel bat setup looks kewl also. One would no doubt need an isolater like motorhomes use. Link to comment Share on other sites More sharing options...
