Gloyale Posted February 10, 2008 Share Posted February 10, 2008 screw, this was covered back on post #18 but reading the old thread (linked to in #20), there may be more going on here than meets the eye. Yeah, I think the 2 threads should be merged. Same car, same problem still. SO, NewDriverOldride, do you still have no CEL light? That is the VERY first thing to solve. NO CEL= NO power to ECU. Does the Horn work???? Check fuse #5 This has been suggested before, please answer this before going any further. Link to comment Share on other sites More sharing options...
Cougar Posted February 10, 2008 Share Posted February 10, 2008 One other note about the CEL light. It should turn on when the ignition is first turned on to test the warning lights. If it doesn't, then something is wrong. Link to comment Share on other sites More sharing options...
NewDriverOlderRide Posted February 15, 2008 Author Share Posted February 15, 2008 EVERYTHING IS FIXED!!!! The optical sensor INSIDE the dist. was bad. rather than buy a new dist, and considering there are no JY around here, it turns out he had a dist from an older nissan where he took that optical sensor and it worked! cool huh!? now on the next note, I just gotta figure out why my wiper motor dont work....hmmmmmmm Link to comment Share on other sites More sharing options...
Cougar Posted February 15, 2008 Share Posted February 15, 2008 Thanks for the feedback. For the wiper motor problem I assume you have checked your fuses already. I would check for voltage getting to the motor next. Link to comment Share on other sites More sharing options...
NewDriverOlderRide Posted February 16, 2008 Author Share Posted February 16, 2008 yea i fixed the wiper motor, alls i did was jiggle the blades a few times, unplug the connector and take the motor apart and back together lol, works tho:banana: Link to comment Share on other sites More sharing options...
Gloyale Posted February 17, 2008 Share Posted February 17, 2008 EVERYTHING IS FIXED!!!! The optical sensor INSIDE the dist. was bad. rather than buy a new dist, and considering there are no JY around here, it turns out he had a dist from an older nissan where he took that optical sensor and it worked! cool huh!? This is A big revalation that could be helpful alot itn the future. What type of Nissan Distributor did you scavange from??? I would love to submit that as a tip to the USRM Link to comment Share on other sites More sharing options...
