is Overcooling bad?
my subaru offroad toy the temp drops to stone cold when going about 50 mph or more when driving around.outside was like 20*F.My radiator is good.in fact right now from the front of the car you can see 100% of of the radiator core so that might have something to do with it.Anyway is Overcooling bad for the engine?
And when the oil never warms up, not only does performance suffer, the places in the engine that need hot oil, may not get that oil. And the real biggie: oil pans tend to accumulate condensation, especially in the winter cold. Oil + water make a really bad combination for lubrication.....and a really nice mess for sludging. Furthermore, your PCV valve is likely to plug up with some really pretty yogurt-like glop. Get a new PCV valve from the dealer.
Check you t-stat - get a new one, (at least a 180 degree one), from the dealer......don't waste your money on aftermarket stats & PCV valves.
Your engine needs at least 160 to 180 degrees of internal oil temp for minimum efficiency, 190 in some engines.
  Uberoo said:
when I start and drive it at low speeds it warms right up and settles about 1/8 of the gauge below the 1/2 mark.And the gauge didnt go to stone cold as I said eariler it was reading about 1/8 of the gauge.
Whats the air temperiture?
nipper
I have the same problem in my hatch, just after you start it and let it sit its fine it goes up to normal and stays. The minute you start to drive and get the wind blowing through it the heat goes away in the motor and worst of all inside the car it's self. It makes for a very cold ride.
Jeff
Jeff
Ditto with the '86 BRAT... 4 year old radiator, new heater core, new Subaru T-stat. Around town, good heat and just below 1/2 mark on gauge. Get out on the road at 50 MPH + and gauge drops below the 1/4 mark, heater is blowing luke warm.... I can watch the T-stat open/close while driving down the road and looking at the temp gauge. It'll rise then fall, then rise again, repeat... This is on a 32 mile trip one-way to work, coming home it'll do better in the temp department. Seems the cold morning air is cause, but I'll find out this weekend as temps are to be less than 10* for high temp around here and I have to work this weekend...
  Uberoo said:
air temp is in the 20's
Then dont worry about it too much. My 87 would do the same thing in the 20's. It was so bad i would block half the radiator with cardboard to get heat.
If it is above 30 or more (yes 10 degrees can make a differnce) then i would worry.
nipper
I was just wondering if it would blow HG if it was too cold.actually it becomes quite warm in the car if I have the heat on,even if the engine temp is cold.must just be because when I cleaned the radiator out it also cleaned the heater core out so its more effiecient at extracting heat.Or maybe its just warm but its ok because I am already wearing a coat and warm clothes from being in the snowy moutains.either way Im fine with it not being super warm.and as far as fuel economy goes,im lightyears away from what my friends are getting in there full size pickups when they go wheeling...so Im happy.
A HG can blow whenever it feels like blowing. It's an old car. If it blows, you will know it. Too cold wont be a HG issue. If it does stay that cold, change your oil a little more often. Make sure your coolant is up to the task.
nipper
During the summer I'd measure the temps on my engine at around 190*F, ie, just right. Since it's been cold here (20's), I only measured ~160* in the same places as before.
Last time I filled up I barely got 20mpg :eek: Granted that's around town in 4WD....
I'm planning to either remove the clutch fan, or block off some of the radiator. Not sure which I'll do yet...
In theory the thermostat should keep the internal cooling loop at the proper temperature, if it opens & closes quickly enough.
-Dave
my wheelin soob is the same way in town with the fan off it will sit at 170 with the fan on around town it sets at 140 on the highway at 50 no fan it runns about 160 with fan on high way 110:eek: but thats just for this time of year idk what it will do in the summer. i still have to put the other electric fan in
