Captin Hook Posted February 10, 2008 Share Posted February 10, 2008 on my way home tonight my oil pressure gauge shot up to like 85 psi and stay there .whats wrong and how do I fix it . 86 gl 3dr m/t 2wd Captin Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 10, 2008 Share Posted February 10, 2008 Short in the sender line to ground. The sender is under the oil pump near the filter. Trace the line and see what it's touching/where the insulation is missing. GD Link to comment Share on other sites More sharing options...
Captin Hook Posted February 10, 2008 Author Share Posted February 10, 2008 Good call will check asap thanks Could it be anything else? Short in the sender line to ground. The sender is under the oil pump near the filter. Trace the line and see what it's touching/where the insulation is missing. GD Link to comment Share on other sites More sharing options...
Captin Hook Posted February 10, 2008 Author Share Posted February 10, 2008 Nope not a grounding prob. wire looks good allthe way to the firewall sending unit is working checked that too. what might be now. Any help would be grate Link to comment Share on other sites More sharing options...
bratsrus1 Posted February 10, 2008 Share Posted February 10, 2008 Hi This is Jerry, if it's not the wire then your oil pump bypass is stuck. Pull the pump there is a spring with a steel ball in it, if the spring is broke or something is in there not letting the ball to move not good. BTW get a oil pump reseal kit before you remove the pump. Thanks Jerry Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 10, 2008 Share Posted February 10, 2008 Also - just to check the wireing for certain - does it read full pressure when the engine is not running but the ignition is on? If so you still have a grounding issue or the sender itself has malfunctioned internally. If not definately follow Jerry's advice and remove the pump. DO NOT drive the car till it's fixed or you risk internal engine damage. GD Link to comment Share on other sites More sharing options...
Gloyale Posted February 10, 2008 Share Posted February 10, 2008 removing the pump won't show you anything. you can examine bypass check ball by simply removing the oil filter. It is visible right there. In fact, if the valve and spring need removed, the cap for it is accesable on the underside of the pump, without removing the timing covers or the pump. Link to comment Share on other sites More sharing options...
Davalos Posted February 20, 2008 Share Posted February 20, 2008 Mine has been doing that too, but only when it's first starting - once it warms-up, it goes down to normal. It's a new OEM pump, too (well, I guess it's a year old now ... ack!) Just started a couple days ago. Link to comment Share on other sites More sharing options...
TeamCF Posted February 20, 2008 Share Posted February 20, 2008 Mine has been doing that too, but only when it's first starting - once it warms-up, it goes down to normal. It's a new OEM pump, too (well, I guess it's a year old now ... ack!) Just started a couple days ago. Mine is the same way. Goes up to about 75psi (however acurate the gauge is) after starting and drops to more normal levels after a couple minutes. Hovers around 25 and goes to 50 if I'm revving it. Link to comment Share on other sites More sharing options...
Captin Hook Posted February 20, 2008 Author Share Posted February 20, 2008 got it all worked out ran a 1/2 can of seafoam in the oil for about a week changed the oil (chucked the ************ty NAPA oil filter and put a K&N filter on there and it stoped ticking "stuck tappet or lifter") and now she runs like a top!!! Davalos and TeamCF try running like a 5w30 in there and a k&N or Fram filter, thay seem to work the best for me i know if i use a napa filter i have a lifter tick and super high oil pressure soo good luck to you guys and thanks to everone that helped me out on this. You guy that are on USMB keep up the good advice you guys rock. Thanks again Captin Link to comment Share on other sites More sharing options...
TeamCF Posted February 21, 2008 Share Posted February 21, 2008 I'll try that. Ya now I think I have a NAPA filter on there now..... Link to comment Share on other sites More sharing options...
mykingcrab Posted February 21, 2008 Share Posted February 21, 2008 mine did it a couple weeks ago. it has always read @45 psi. under normal driving.(mobil 1 synthetic) Link to comment Share on other sites More sharing options...
Davalos Posted February 21, 2008 Share Posted February 21, 2008 mine did it a couple weeks ago. it has always read @45 psi. under normal driving.(mobil 1 synthetic) Your stereo looks like mine used to look, hehe! I'm gonna do the seafoam/deisel flush here this weekend. See how well that works. She needs a new change anyway. This TOTALLY wouldn't bug me if it were the gas gague doing that! I'd be like "Yeah, baby!!" Link to comment Share on other sites More sharing options...
mykingcrab Posted February 21, 2008 Share Posted February 21, 2008 Your stereo looks like mine used to look, hehe! I'm gonna do the seafoam/deisel flush here this weekend. See how well that works. She needs a new change anyway. This TOTALLY wouldn't bug me if it were the gas gague doing that! I'd be like "Yeah, baby!!" Sharp!!!!!!!!, its in the works,you know:grin: Link to comment Share on other sites More sharing options...
Davalos Posted February 25, 2008 Share Posted February 25, 2008 Hmm ... so I drained it out, filled'er up with deisel, drained it again, pulled & changed the filter, and ... Same thing. Hmmm. 10w40 with 1/2 quart of Lukas Mystery Oil ... Link to comment Share on other sites More sharing options...
mikeshoup Posted February 25, 2008 Share Posted February 25, 2008 try running like a 5w30 in there and a k&N or Fram filter, thay seem to work the best for me i know if i use a napa filter i have a lifter tick and super high oil pressure You don't want to start an oil filter war with those words. Fram is sworn by many people to be the worst brand of oil filters. My wagon ticked like a mother trucker when I bought it, and it had a Fram filter. I don't know if it was changing the oil filter or the oil, but it stopped ticking. I run cheap Chevron 10W-30 and Nippon Denso filters. Used to run Napa filters until I got a crap load of these Nippons from a shop back near my mom's house. I'm not going to say Frams are necessarily bad (though I'll never run them after I've seen the insides of one), if they work for you, then they work for you, but don't swear by them. Link to comment Share on other sites More sharing options...
nipper Posted February 25, 2008 Share Posted February 25, 2008 Mine is the same way. Goes up to about 75psi (however acurate the gauge is) after starting and drops to more normal levels after a couple minutes.Hovers around 25 and goes to 50 if I'm revving it. Thats normal on a cold engine in winter. The oil is really thick. My 1987 used to peg the gauge till the oil warmed up. nipper Link to comment Share on other sites More sharing options...
