The fans will also run if you have the climate on any a/c or defrost setting and sometimes if you have it on 'auto'. Also you will not see enough flucuation in the temp gauge pointer to show when the fans are coming on and off. Typically the fans come on around 202F engine coolant temp if you are stopped.
Now there was a recall IIRC for certain soobs of that era with the cooling fan relays having issues and fans running all the time, but I think that was even if the key was off but I forget....
