lostinthe202 Posted February 19, 2008 Share Posted February 19, 2008 EVOthis said: i have a photo here and was wondering if anyone can tell me exactly what is a normal idle on a 1996 subaru legacy L 2.2 My '96 OBW 2.2 idles at just above the first mark on the tach and idles just below 1000 with the a/c on. Sorry I know that's not very precise. Will- EDIT - it's a 5spd Link to comment Share on other sites More sharing options...
EVOthis Posted February 19, 2008 Author Share Posted February 19, 2008 thats ok...i cant seem to find anything in my cilton book....:-\....... Link to comment Share on other sites More sharing options...
ericem Posted February 19, 2008 Share Posted February 19, 2008 Thats odd did you try reving it a bit and letting the idle drop?? Hey porcupine when you unplug the IACV line does your car still idle?? Mine just dies has always been like that just wondering its its a problem though. Link to comment Share on other sites More sharing options...
lostinthe202 Posted February 19, 2008 Share Posted February 19, 2008 EVOthis said: thats ok...i cant seem to find anything in my cilton book....:-\....... Eh, yeah, I can't find my chilton book:slobber: Link to comment Share on other sites More sharing options...
EVOthis Posted February 19, 2008 Author Share Posted February 19, 2008 yeah i drove it home like that today and everystop sign or stoplight the idle stayed right there......do you have any idea how to hook up a DVOM to read the RPM's because i have the meter with the capability to do it i just dont know where to hook it up....... Link to comment Share on other sites More sharing options...
subaruplatt Posted February 19, 2008 Share Posted February 19, 2008 EVOthis said: Ok ive got a 96' legacy ej22 with a 5 spd....i know ( or at least i think) that the IAC Valve on the 1.8 and the 2.5 engines are part of the throttle body....my question is....are there any differences on the 2.2 liter engines.....ex : could i swap an IAC from any other year 2.2 liter and put it on my 2.2?.....im making a junkyard run tomarrow and just trying to get some advice..... ( dont feel like paying $350 for a new IAC from the dealer......thanks in advance..... Is the iac valve downstream from the pcv re-vent? If so my theory is that blow by oil will combine with dust and clog the iac. What is interesting is that the oil and dust mixture mimics electrical malfunction so well, as the "fuzz" seems to cause more problems during extremely damp periods. So a simple breathing issue will masquerade as an electrical fault. Used to have a near yearly event with the 95 Vr6 I used to have. Fill choke and repeat with gas line anti freeze. 2$ fix. Warning! Hot engines may present a fire hazard. Choke, puff of smoke and then no more problem. Link to comment Share on other sites More sharing options...
EVOthis Posted February 19, 2008 Author Share Posted February 19, 2008 well if you look at it like i do the PCV is downstream of the IAC.....im going to do a vacuum test tomarrow and i ordered a new IAC valve gasket...hopefully that will get my idle back to normal like it prob. was.......i would still appreciate any suggestions anyone has........ Link to comment Share on other sites More sharing options...
frag Posted February 19, 2008 Share Posted February 19, 2008 EVOthis said: ok...i replaced the IAC today ( didnt use a new gasket) as soon as i started it up the idle went to like 2500 and didnt move also got a CEL code 505.....so obviously the other IAC didnt work.....it seemed pretty gunky in the vacuum lines around the IAC so i cleaned them out and put the old IAC back on.....it seems to idle a little higher.....i have a photo here and was wondering if anyone can tell me exactly what is a normal idle on a 1996 subaru legacy L 2.2....Also i have a digital volt ohm meter with a Tach. function.....does anyone know how to hook that up so i can properly read the engine RPM..... A little too hign in my opinion. That's over 750 rpm and normal idle is closer to 700 rpm. When idling at operating temp the needle on my tach is just below that same line. Has been idling there for 7 years, execpt for the period when I had a burnt exhaust valve. Link to comment Share on other sites More sharing options...
EVOthis Posted February 19, 2008 Author Share Posted February 19, 2008 thanks for the tip....... Link to comment Share on other sites More sharing options...
porcupine73 Posted February 20, 2008 Share Posted February 20, 2008 Hi. I have a '96 2.2L (auto though), with a scangauge, so I can tell you a good average of idle (after warmup) tomorrow. Also the correct (non user adjustable) idle speed range should be shown on one of your underhood stickers. If your idle is consistently high one possible cause is a vacuum leak. Link to comment Share on other sites More sharing options...
EVOthis Posted February 20, 2008 Author Share Posted February 20, 2008 yeah i started to look there and i remember that it is not the origonal hood.....its off of like a 98 GT or something....i did order a new gasket for the IAC and am going to look for a new hose (one of them seemed brittle and showed small signs of cracking).....if a vacuum leak is present is there a chance it could give me problems throughout my RPM range?....im also going to do a vacuum test when i get the chance...i did one a while ago before i messed with this problem and everything seemed normal except for maybe a variation of not even 1 hg. up and down....the needle was pretty much steady at about 18 at idle......again i do appreciate your help porc....... Link to comment Share on other sites More sharing options...
porcupine73 Posted February 20, 2008 Share Posted February 20, 2008 Sounds good. Quote if a vacuum leak is present is there a chance it could give me problems throughout my RPM range? I guess if you had a big enough leak it could. It doesn't take much of a leak at idle to make the rpms go up. When on the throttle the ECU can compensate by altering fuel trim. On my '96 last year I noticed the idle was quite a bit higher than usual, but no other driving issues, and it was the tubing I had run for my vacuum gauge cracked. Link to comment Share on other sites More sharing options...
EVOthis Posted February 20, 2008 Author Share Posted February 20, 2008 did you get a chance to take a look at engine RPM at idle? Link to comment Share on other sites More sharing options...
porcupine73 Posted February 20, 2008 Share Posted February 20, 2008 hehe I knew I forgot to do something this morning.......ok I will have to check it out on the way home! Link to comment Share on other sites More sharing options...
EVOthis Posted February 20, 2008 Author Share Posted February 20, 2008 thanks alot porc......i just did a vacuum test and the needle had an almost steady reading at 20 in. hg at idle.....so according to that everything is good.....i also called subaru they said my gasket will be in tomarrow.......if my IAC was having a problem would it have shown up on the vacuum test?..... Link to comment Share on other sites More sharing options...
porcupine73 Posted February 21, 2008 Share Posted February 21, 2008 Good morning. Ok I remember to check my idle '96 legacy 2.2L auto trans (I can't remember is yours a manual trans?), after a 33 mile drive for warmup, all accessories etc off, it was ~700rpm in park and ~650rpm stopped in drive. I forgot to look at the vacuum gauge though. I had a picture of my underhood sticker with the idle range but I can't find it right now. Let's see the service manual says....... Idle Speed - unloaded 700 ±100 rpm (With Headlights, Heater Fan, Rear Defroster, Radiator Fan, Air Conditioning, etc. "OFF") Idle speed, loaded 850 ±50 rpm (Turn Air Conditioning (A/C) Switch to "ON" and operate Compressor for at least one minute before measurement.) Link to comment Share on other sites More sharing options...
EVOthis Posted February 21, 2008 Author Share Posted February 21, 2008 thanks porc....yeah i vacuum gauge showed a healthy engine but idle seems a little high.....im still trying to figure out how to hook up a DVOM on the tach function.......any input would be great..... Link to comment Share on other sites More sharing options...
frag Posted February 21, 2008 Share Posted February 21, 2008 EVOthis said: thanks porc....yeah i vacuum gauge showed a healthy engine but idle seems a little high.....im still trying to figure out how to hook up a DVOM on the tach function.......any input would be great..... Have a look a this: http://www.ultimatesubaru.org/forum/showthread.php?t=84440 Link to comment Share on other sites More sharing options...
EVOthis Posted February 21, 2008 Author Share Posted February 21, 2008 thanks frag....i know i posted that a while ago....i guess i kind of overlooked the post that explained that.....ill give it a whirl... Link to comment Share on other sites More sharing options...
EVOthis Posted February 21, 2008 Author Share Posted February 21, 2008 ok.....i got home got my multimeter and found out i could use an inductive pickup to measure my RPM's...so i clamped the pickup around #1 cylinder plug wire and got a reading fluctuating from about 650-850 PRM's fully warmed up in neutral....i dont know how good inductive pickups are for measuring RPM's.....the meter was kind of running around from 650 to 850....my pics wont upload for some reason but my Tach on the dash is in the same exact spot as the pic. i took yesterday...... Link to comment Share on other sites More sharing options...
