soobyfan Posted February 15, 2008 Share Posted February 15, 2008 I have a '96 OBW, 2.2L 5sp. When I am driving at highway speeds I occasionally hear a sound like something loose or ringing. It is not real loud, and does not seem consistent. It seems to be coming from the drive train. I am wondering about wheel bearings, transmission, rear diff, rear driveshaft? Any input would be appreciated. Link to comment Share on other sites More sharing options...
Rooster2 Posted February 15, 2008 Share Posted February 15, 2008 If the sound is a slight buzzing ringing sound, it is prolly because the metal shroud around the exhaust pipe under the car has become loose. That has happened on both my 98 and 99 Leggy OBWs. It is nothing to be concerned about; it just becomes annoying to listen to. I quieted the noise by driving the car up on ramps, crawled under the car, then had someone hold the gas pedal down to precisely the engine rpm that caused the shroud to buzz. Using a screw driver, I pressed it against the shroud until I got the noise to stop. That told me where the shroud was loose. To repair, I got a bolt, using a hammar, I drove the bolt in like a wedge to prevent the loose shroud from vibrating. It worked great. No more shroud noise for the past couple of years. Link to comment Share on other sites More sharing options...
lostinthe202 Posted February 15, 2008 Share Posted February 15, 2008 soobyfan said: I have a '96 OBW, 2.2L 5sp. When I am driving at highway speeds I occasionally hear a sound like something loose or ringing. It is not real loud, and does not seem consistent. It seems to be coming from the drive train. I am wondering about wheel bearings, transmission, rear diff, rear driveshaft? Any input would be appreciated. You could try getting under there and shaking things around to see if you have anything loose like a heat shield or the exhaust or something. What makes you think it's the drivetrain? Will- Link to comment Share on other sites More sharing options...
idosubaru Posted February 15, 2008 Share Posted February 15, 2008 those metal exhaust shrouds are really bad for this kind of stuff, good chance that's what it is. i've crawled under subaru's and seen metal hose clamps holding them type, sheet metal screws drilled into the exhaust...people come up with some good ones for settling that down! Link to comment Share on other sites More sharing options...
