cd45 Posted February 15, 2008 Share Posted February 15, 2008 Problem, the blower keeps going off. I replaced the blower motor, and that worked for a week. This morning, it went off in less than 10 miles. Is it the resistor or the relay? I know which one I hope it is but, I am sure it will be the expensive one. Link to comment Share on other sites More sharing options...
one eye Posted February 16, 2008 Share Posted February 16, 2008 cd45 said: Problem, the blower keeps going off. I replaced the blower motor, and that worked for a week. This morning, it went off in less than 10 miles. Is it the resistor or the relay? I know which one I hope it is but, I am sure it will be the expensive one. I just took a jumper wire from the wire on the back of the switch right to the blower motor. Then I replaced the block that was right on the bottom part of the Blower here is a the link to what I had going on. http://www.ultimatesubaru.org/forum/showthread.php?t=84226 If you move down a bit you can see what I was talking about. I hope that helps you. Jeff Link to comment Share on other sites More sharing options...
Cougar Posted February 17, 2008 Share Posted February 17, 2008 If the blower will work on high speed then the resistor block is bad. If it doesn't work at all then the relay or switch may be at fault, or also the motor. Link to comment Share on other sites More sharing options...
