Converting FWD to 4WD
Pebbles
Youll need a 4WD gas tank, rear suspension, trans, etc.. it all pretty much bolts in. The only thing I had to weld in was the 2WD cars don't have the mounting bracket for the 4WD shifter, but it's relatively simple to cut it out of the donor car and weld it into the proper place in the car you are converting. That was really the only part that was a PITA, that and the fuel tank since it has like 12 lines going to the top of it.
