3Pin Posted February 20, 2008 Share Posted February 20, 2008 Will this have the 2.2 or the 2.5? Does anyone know. It is not the GT version, just a regular 4 door sedan. Link to comment Share on other sites More sharing options...
GLCraig Posted February 20, 2008 Share Posted February 20, 2008 it's most likely a 2.2. Look under the power steering pump and you will see the casting mark of either EJ22 or EJ25. An EJ22 is a 2.2 and an EJ25 is a 2.5. Link to comment Share on other sites More sharing options...
Suzam Posted February 20, 2008 Share Posted February 20, 2008 The GT and LSi were the only model of MY96 Legacy with the 2.5 all the others have the 2.2, you can also check under the hood for a sticker that will tell you engine size. Link to comment Share on other sites More sharing options...
johnceggleston Posted February 20, 2008 Share Posted February 20, 2008 The GT and LSi were the only model of MY96 Legacy with the 2.5 all the others have the 2.2, you can also check under the hood for a sticker that will tell you engine size. also, the 96 outback auto had the 2.5L engine. all of the legacys L, LS, brightons, and the outback w/5spd had the 2.2L. Link to comment Share on other sites More sharing options...
3Pin Posted February 21, 2008 Author Share Posted February 21, 2008 Does anybody know if I can transplant the 96 2.2 into a 95 legacy easily? Link to comment Share on other sites More sharing options...
johnceggleston Posted February 21, 2008 Share Posted February 21, 2008 Does anybody know if I can transplant the 96 2.2 into a 95 legacy easily? yes, easy. but you'll need the y-pipe of the exhaust that matches the 'new' engine. one year has dual port exhaust, one year has single port. Link to comment Share on other sites More sharing options...
idosubaru Posted February 21, 2008 Share Posted February 21, 2008 Does anybody know if I can transplant the 96 2.2 into a 95 legacy easily? what is the 95 legacy - manual or automatic? a 95 manual trans vehicle won't have an EGR set up with it so you'll have to block the EGR stuff off of the 96 2.2. Link to comment Share on other sites More sharing options...
johnceggleston Posted February 21, 2008 Share Posted February 21, 2008 what is the 95 legacy - manual or automatic? a 95 manual trans vehicle won't have an EGR set up with it so you'll have to block the EGR stuff off of the 96 2.2. or, since they are both ej22s, swap intakes. but this would really only be necessary if putting the 95 w/o EGR into a 96. Link to comment Share on other sites More sharing options...
idosubaru Posted February 21, 2008 Share Posted February 21, 2008 copy that - the blocks w/o intake manifold will interchange no problem! Link to comment Share on other sites More sharing options...
