hatch4x4 Posted December 20, 2003 Share Posted December 20, 2003 EA-81 here: I replaced my clutch with my engine swap last spring. It always had a bad shudder so I finally got around to trading it in under warantee at schmucks. Also picked up a refurbed flywheel. Popped all of the above in and now it slips bad. I even adjusted my linkage to the point where I have about 2 inches of freeplay before I start to feel resistance. As soon as I even touch that resistance, it is basically disengaged. I am thinking I got a bum pressure plate. Any ideas? -- Jeff Link to comment Share on other sites More sharing options...
edrach Posted December 20, 2003 Share Posted December 20, 2003 Sounds like something is basically wrong there. I've never had a car that would allow 2" of freeplay much less disengage so suddenly. If Schucks' rebuild shaved too much off the flywheel that would certainly account for your symptoms. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 20, 2003 Share Posted December 20, 2003 Yeah - grab a flywheel from the JY - you can get em off pretty easy without completely removing the engine - just pull it forward to get to the flywheel. Then you can either use it if it looks good, or get it turned..... my last JY flywheel was good enough to use, and it cost me $11 + tax. GD Link to comment Share on other sites More sharing options...
calebz Posted December 20, 2003 Share Posted December 20, 2003 Sounds kinda like the TO bearing/clutch fork is hanging up.. Did you clean off the shaft and grease everything up really well? Link to comment Share on other sites More sharing options...
rallyruss Posted December 20, 2003 Share Posted December 20, 2003 sound like the fly wheel is suspect. if they did not machine the steps properly it could do that. or as you are thinking a bad pressure plate. they are not realy known for high quality parts there so who knows. the disc is in properly right? Link to comment Share on other sites More sharing options...
LUVMYBRAT Posted December 20, 2003 Share Posted December 20, 2003 you should also try the clutch cable. I was having some similar issues and it was really pissing me off, finally the cable broke and i had to replace. it was like getting a totally different car. 23.00 and 20 minutes is easier than pullin everything again. It took me two complete kits and 5 times of pullin to get it right. thank God it only takes 25 minutes to pull Link to comment Share on other sites More sharing options...
Qman Posted December 20, 2003 Share Posted December 20, 2003 Jeff, what year is your Hatch? Link to comment Share on other sites More sharing options...
hatch4x4 Posted December 20, 2003 Author Share Posted December 20, 2003 It was born in 81 but pretty much the body is the only thing still stock. The engine, flywheel, clutch, and transmission are all 83. None of that 7 7/8" clutch here. -- Jeff Link to comment Share on other sites More sharing options...
