XT6 in a Vanagon. Possible?
you're better off with a newer engine - the EG33 is an EXCELLENT choice. the ER27 is nice because they're cheap...but they leak oil, are easy to work on but are still likely to leak, expensive and hard to find parts for....the EG33 is an excellent motor - much better power, newer, and i'd guess more reliable. but they can be hard to find parts for too. the EJ25 is nice...easy to find, easy parts but have head gasket issues - so beware of those.
dont know anything about the conversion but the XT6 is a different bellhousing than the EG33 and EJ25 so a conversion kit won't be identical, but the motor mounts should be in nearly the same locations as the EJ25 if that helps at all.
  • 5 months later...
