hi,I have an 04 obw. and for some reason the intermitent wipers are not working.they worked fine then one day they just stopped.the wipers work if i pull the arm down to fast.and the little dail still seems to work fo the rear.is it the little arm switch or th wiper engine??? or??? and is it easily fixed?
I have a warenty but if i can fix it easily myself i would rather do so. and not pay the deductable. any help?
if you are freindly with a multimeter?
We can get you the switch wiring for the connector
under the panel covering the lower steering coluum.
Then you can track it down to the delay control unit
or the switch.
