inner tierod EA81 manual steering TIPS
a long time ago i once put ea82 inner tie rods on an ea81 manual rack formy ea82 suspension conversion
there is a flat washer thet is folded over the lock nut. if i'm not mistaken the inner threads are left hand. it has been a while hence my vague recollection.
i remember having more difficulty slipping the boots back on if anything
I would put on new boots as well. They are like $15 each from rockauto.com...... made by spicer IIRC.
After spending $150 on the inner tie rods, I wouldn't be wanting any grit getting in there.
Otherwise they are simple - just bend back the washer with a screwdriver and spin them off. Take the whole thing off with the end and all. Carefully measure the distance to the ends and make the new one's the same length.
Just to clearify it would be $150 for all four tierods. I'm just doing the passenger side this time around.
I'll be sure to do the boots too. Thanks for the tips, Tim
