6inch lift kit home build
ivantruckman
i wanted to do my own lift kit, im a stubborn cuss.. i found out why others get the money they are asking. these kits like scotts are actually very reasonably priced when you consider the time involved in fabracating, but i have to prove that i can do it, but im considering buying the next one.
day one
http://s247.photobucket.com/albums/gg137/ivantruckman/?action=view&current=strutower.jpg
http://s247.photobucket.com/albums/gg137/ivantruckman/?action=view&current=6inchblocks.jpg
http://s247.photobucket.com/albums/gg137/ivantruckman/?action=view&current=liftkit1.jpg
When I did mine, I looked at the 2X2X6 blocks, and they looked kinda flimsy to me, especially if you are going to connect them, so I plated one of the open sides, now I know they won't do anything weird.
I didn't mind building it and would do it again.
Of course it helps when a neighbor drops by and asks: "where did you buy that lift kit, I didn't know you could buy one for those cars?"
hey scott ..the pipes are 4 1/4 od .125 wall i cut the flanges with a plasma cutter, i cut out a template out of wood , and use a drag sheild. still a lot of work to do. and steel prices have gone up big time, i used drop peices at the local steel shop, but i still have about 100 bucks in small peices of steel..
http://s247.photobucket.com/albums/gg137/ivantruckman/?action=view&current=blockinstall.jpg
  • 3 weeks later...
one question for all who have made their own lift kit...
why extend the struts up? where they sit stock is likely the best place for them, your not going to be rubbing your tires on the spring...? no angles, just add the extension to the bottom.. maybe im wrong here but sometimes simple is better.
This is what I did. I took a new strut, cleaned off the brackets, cut an old strut bottom (with brackets) 7" in length, measured the length, looked high, and low, for a piece of tubing to sleeve the assembly in a shrink fit situation (freeze strut, and bottom piece, heat tubing) quickly assemble, weld tubing to spring mount on the top, and the bottom piece.
End result: bad camber
Remove lower control arms, and lengthen by an inch, plating the bottom for extra strength, slot upper strut mount holes, and now the camber is under control AND fully adjustable.
Looking back at it I should have just made the offset top mounts, but I know that my stresses created by driving is in line with what it was originally, and not offset.
  • 1 month later...
  ivantruckman said:
There is a little icon for inserting a picture, it looks like a little mountain and sun or some such.
  ivantruckman said:
There is a little icon for inserting a picture. You need to use the "direct link" one, not the "email IM" one that you used.
  • 2 weeks later...
Kewl work. There definatly is a sense of pride when you do something like this yourself. Keep up the work.
As for the strut extension, a lower extension is the way to go. I started with an upper, but the tires would rub all the time. I've been running my 7" lowers for about 4 years now, holding up strong. They are made from 1/4" wall that I pressed onto the strut. I did have a little trouble with the knuckle falling off the strut at full extension, so I added the tab. (if I had knuckles in better condition, it wouldn't have been a prob, but mine are pretty abused.)
Only problem with the strut bottom extension is the camber.
If you just effectively lengthen the shock, you are pushing the top of the knuckle outward. end up like this \-/
With strut tops, you can make them with an angle to compensate, and actually improve over stock camber.
