Rear Axle Questions...
I know the front axles are different between the turbo/non turbo and also a/t and m/t... 23 spline or 25 spline.
Havent played with the rear in quite a while, cant remember if there's anything different about the REAR axle inboards.. turbo? Non-turbo? Spline count?
My rear axle crapped on me and I have 2 non turbo axles laying around that I could rebuild, cant seem to find a listing for turbo Rear axles..
Input? Advice? Thanks in advance.
  • 1 month later...
yep all rear EA82, EA82T, and ER27 rear axles are the same.
Okay dokie. :banana: I'm not gonna count my chickens just yet.... Gary, I'm wanting to clarify a couple things please.
I have XT6 rear and front axle shafts that need replacement.
I have a GL-10 turbo wagon(s) one has 3.9 ratio and the other has 3.7
There are a couple "other" shafts on the storage area that will need to be looked at and spline counted.
What you say(And I trust you bigtime) is that the rears are the same size and spline count of the rears for all three cars, right?
Chux & Gary, You rock... now to go count the shafts and spline to see what is where and swap oput the toasted rears and see about ordering them GKC(sp) thru amazon......
side note to self( gotta bump up the thread on the TPS issue and ask about the HLA thread with the cool pic's on disassembly and cleaning.... )
