EA81 headrest removal IS possible!
I'm trying to remove them to put on some awesome NOS vintage seatcovers i've been waiting for the right car to put them on. Before i hack up the covers, is it even possible to remove the headrest for seatcover installation?
Checked for any signs of a button, nada.
Adjustment is made by pulling the actual headrest straight up.
It is either all the way up or down, there are no notches in the bars etc. to hold it in any particular position.
Same button used to adjust them. Just pull straight up till they come off.
I tried the same thing about a week ago. If you don't have a release button, the only way to really detach them is to take the cover off, then reach in and undo the pin and stuff that holds them in there. I took the easy way out since all i needed from the seats were the covers - a sawzall zzz
Problem solved!
You might have to just pull harder.
Right on the money. From the lowest position, you have to pull it as hard as you can, as if you were expecting it to come out. I pulled a little too hard and fell backwards when it came out, but the second one wasn't as awkward.
end results:
