1996 Legacy LSI Automatic EJ25
I pulled the engine and transmission out and can't recall if there was anything originally plugged into these plugs. My other Legacy has them both too but also doesn't have an engine in it!
Plug1 - is located behind the battery and close to the windshield washer fluid tank.
Plug2 - is located behind the drivers side headlight. The one behind the drivers side head light "Plug2" I believe is always open. But still curious what it is.
[...]Plug1 - is located behind the battery and close to the windshield washer fluid tank.
Cars that have rear washers have a tank with two pumps. If I'm seeing things in the pic properly, I think that connector would go to the pump for the rear, if it existed.
looks like the plug behind the headlight goes to the horn, which seems to be absent, and the other i think is not used, i want to say that it is there for a different washer pump./ resiviour. i think there was a version with headlight washers or something like that. on every legacy ive seen, that plug has been just hanging out.
