Pooparu Posted March 5, 2008 Share Posted March 5, 2008 So I have located the black wire coming out of the EJ's ECU labeled tachometer on the wiring diagram and connected it to the solid yellow wire that came off of my EA's coil and my tachometer still doesn't work. Is there something else I need to hook up or what am I doing wrong? thanks, earl Quote Link to comment Share on other sites More sharing options...
mellow65 Posted March 5, 2008 Share Posted March 5, 2008 what am I doing wrong? you need to stop twisting and taping your wires, that's what's wrong. ok now i'll let the real people that know what they are talking about answer Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 5, 2008 Share Posted March 5, 2008 Everything I've read says it just hooks straight up to the ECU tach signal as you have it. Perhaps a ground issue is at work here. GD Quote Link to comment Share on other sites More sharing options...
kingbobdole Posted March 5, 2008 Share Posted March 5, 2008 Check your wiring again. On my EJ25 swap there are 2 wires going to the EJ dash, and one was for the spedo. Are you sure you grabbed the tach signal for the dash as well? Quote Link to comment Share on other sites More sharing options...
Pooparu Posted March 5, 2008 Author Share Posted March 5, 2008 Check your wiring again. On my EJ25 swap there are 2 wires going to the EJ dash, and one was for the spedo. Are you sure you grabbed the tach signal for the dash as well? I'm not sure. I just hooked the one wire that ShawnW labeled as Tachometer up. Quote Link to comment Share on other sites More sharing options...
Hondasucks Posted March 5, 2008 Share Posted March 5, 2008 So I have located the black wire coming out of the EJ's ECU labeled tachometer on the wiring diagram and connected it to the solid yellow wire that came off of my EA's coil and my tachometer still doesn't work. Is there something else I need to hook up or what am I doing wrong? thanks, earl Are you meaning the wire to the coil itself, under the hood? Wire it to the tach signal wire under the dash that goes to the cluster, I don't have my FSM handy so I don't know what pin it is on the connector to the cluster. Quote Link to comment Share on other sites More sharing options...
