ea82 wont crank over
ok i know you all hate me but i have an ea82 and when i turn the key on all the lights come on but it wont turn over no lights dim or anyhting i tryed to jump it and it didnt work i checked all my fuses and ground car worked fine last time i started it what could be wrong i searched for the thread about this but couldent find it thanks Rob:(
car, mileage, auto/manual?
there's a few possibilities.
jumper cables can vary a lot. i have one set that won't jump anything, just too weak. i have another set that's huge, heavy duty, heavy gauge and it works every time if i can get a good connection. so are you sure you had a good set of cables?
the starter would be suspect - try the old "whack the starter a few times" trick and see if it cranks over then.
a multimeter would be nice, make sure you're getting voltage to the starter and make sure the ignition is switching properly.
if it's an automatic - it's not in a drive gear is it?
